02-20-2013, 01:16 PM | #1 |
Drives: 2013 2LT RS Black and Silver Join Date: Feb 2013
Pandora Problem
I am a new owner and there is Pandora on mylink and I have it on my iphone 4s but when I click on Pandor on phone the icon does not light up to play. I will play off my phone through the bluetooth but I thought it was to play from the icon on mylink. I tried plugging phone into usb and that did nothing. Can someone help me figure it out? thanks
02-20-2013, 01:20 PM | #2 |
Drives: 2013 inferno orange metallic ss Join Date: Jan 2013
I have that problem sometimes, but i dont have an iphone anymore, but ill play through bluetooth, then the pandora light will pop up shortly after.
02-20-2013, 01:20 PM | #3 |
Let's go Rangers!
You have to change the source to Aux, then select pandora from the screen
02-20-2013, 03:03 PM | #4 |
@nyrfan
That icon does not let me select it either. The stitcher, pandora, usb and aux will not let me select it. Do i take phone off bluetooth then plug into usb and then select aux? So my last car was not that fancy. |
02-20-2013, 03:27 PM | #5 |
Drives: CHEV TAHOE CHEV IMPALA 69' COUGAR Join Date: Nov 2009
You have to pair your phone to the bluetooth in the car then the Pandora app will light up.Make sure your volume on the phone is turned up and it will stream without a cable.At least it does with my Droid.
02-20-2013, 05:12 PM | #6 |
Drives: 2013 Victory Red 2SS Join Date: Aug 2012
You just have to be connected via bluetooth and all the pandora, stitcher options will light up. Sometimes it does goof up. Just try reconnecting or restarting myLink and it should work. Its meant to be played through myLink and not the phone. But I have Galaxy S III, I'm hoping should be the same for iPhone.
iphone, pandora |
