View our official forum sponsors list. |
Thread Tools |
12-11-2017, 02:17 PM | #15 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
12-12-2017, 05:31 PM | #16 | |
Drives: 2015 2LT RS Convertible Join Date: Dec 2016
What kind of diet are you on?
You need to post a video of you getting into the car. |
03-21-2018, 02:07 PM | #17 |
2010-2015 Camaro Window Valet
Installation for the Camaro is just like it was for the C5 and C6. It just plugs into the diagnostics port. No wires, no cutting, no tools. Once installed, the Window Valet™ for Camaro is ready to run. There's no configuration required. And, as always, Window Valet's do NOT reprogram the car's computers. Description: The Window Valet™ for Camaro provides remote power window control for the 2010-2015 Camaro. ** Moving power windows can be dangerous if someone or something were to become pinched or trapped. By installing this product, you agree to the Terms of Use, Warranty, and Liability Waiver. Never use the remote power window feature unless both windows are completely clear of obstructions. Installation: The Window Valet™ for Camaro plugs into the diagnostics port, near the edge of the dash trim. There's no configuration required. Just plug it in! The Window Valet™ for Camaro does not reprogram any of the car's computers. So to reverse the install, just unplug the unit, and the car will immediately revert back to stock. Usage: To lower the windows via remote, press the remote unlock button three times. To raise the windows, press the remote lock button three times. (Or to prevent the car from blowing its horn multiple times, unlock-unlock-lock may be used.) For the features to activate, the buttons must be pressed in rapid succession, with less than one second between two sequential clicks. Special Window Venting Feature: The window venting feature allows you to use the remote to leave the windows down about half-an-inch for airflow on hot days. To use this feature, simply issue the remote window up command, wait until the windows have been fully raised, wait a couple of more seconds, and then press the remote lock button one more time. The windows will lower just a fraction of an inch. Note: The Camaro may toot its horn on the second and third remote lock commands even if its horn configuration is set to silent when locking. This is a feature of the Camaro, not the Window Valet™, and is designed to act as a lock confirmation. To prevent the horn from blowing when remotely raising the windows, you may use the alternate window up command sequence: Unlock, Unlock, Lock. Item # C7V800C Use coupon Code LANA5 online or by phone when ordering and receive 5% off the listed website price and this item ships for FREE!! Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5532 |
09-23-2019, 02:06 PM | #18 |
11-18-2020, 09:53 AM | #19 |
Use Coupon Code RPISHELLEY5 For Immediate Savings
12-08-2021, 02:47 PM | #20 |
Use HOLIDAYS to claim your discount upon checkout
https://www.rpidesigns.com/shop/item.aspx?itemid=5532 |
01-16-2023, 10:37 PM | #21 |
Thank You for shopping at https://www.rpidesigns.com/shop/item.aspx?itemid=5532
