01-16-2020, 08:56 AM | #169 |
Certain types of Stainless will in fact show surface rust. Flowmaster uses that type of stainless(409). It's not pure stainless...a magnet will stick to the mufflers and pipe but not the tips.
2016 NFG 1SS A8
01-16-2020, 10:21 AM | #170 |
Drives: 2017 2SS M6 Join Date: Jun 2013
it will took mine a while befor it started to rattle.
01-16-2020, 10:44 AM | #171 |
Did you guys cut the tabs in your npp actuators per the rattle tsb?
22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28 dragpack - 11.68@122
16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
01-16-2020, 10:48 AM | #172 |
? cut what
01-16-2020, 10:54 AM | #173 |
If you haven’t done this you might be good to go.
This cleaned up all my rattle, it’s nuts https://www.camaro6.com/forums/showthread.php?t=556061
01-16-2020, 02:35 PM | #174 |
Oh damn, I am going to try that. Thanks for the heads up!!
2016 NFG 1SS A8
01-17-2020, 12:31 PM | #175 | |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
Most modern factory exhaust systems are made from 409 stainless steel. It is strong and will last 8-10 years in a moderate climate. 409 stainless steel will rust on the surface. However, this is not a concern for most people because it is hidden under the vehicle. Surface rust can be cleaned with a wire brush. 304 stainless is the highest quality material used for exhaust parts. It will last 10 years or more in a moderate climate. However, it is the most expensive. It will not rust for many years. But, it will turn a golden brown color after being exposed to heat. |
01-17-2020, 07:26 PM | #176 |
Yep I agree.
2016 NFG 1SS A8
01-23-2020, 01:03 AM | #177 | |
Drives: 2020 1SS 1le Join Date: Apr 2019
This post is why I come to the forums. |
01-29-2020, 07:22 PM | #178 |
U guys have any luck?
01-29-2020, 10:33 PM | #179 |
No not yet...probably won't mess with it till spring when I get the car out of hibernation.
2016 NFG 1SS A8
02-05-2020, 02:21 PM | #180 |
Drives: 2016 Camaro 1SS M6 Join Date: Jun 2016
I welded my secondary cats back in made it about 20% quieter and got rid of most of the drone. I also pulled the npp fuse and rattle is gone forever. It also sounds better because you dont hear it open and close from when your revving in neutral. I think the flowmaster npp sounds fine without any other mods and is not too loud to make any neighbors angry.
american, axle, dual, flowmaster, npp |
