11-20-2015, 07:14 PM | #1 |
Drives: C7 Stingray Join Date: Nov 2015
Battery protection/charger question
I have a 2016 coupe. When I plug in the Corvette battery tender in the rear power port, is it ok to let the hatch close against the cord? I worry if the cord will crush a portion of the rubber seal and allow water leaks in the Spring when I remove the cord.
11-21-2015, 02:27 PM | #2 |
Drives: '16 Z06 7 Spd, 2024 High Country HD Join Date: May 2015
It does not hurt the cord but keep the cord away from the hinges and latch. The charger will NOT work on any of the recepticals in the console area.
11-21-2015, 03:14 PM | #3 |
Drives: SS,PaceCar,ZL1,1LE,C7Z51,Z06,17-ZL1 Join Date: Jun 2009
11-26-2015, 06:33 AM | #4 |
I extend mine through the front cabin and out the driver side window (only put the window down far enough for the cord to go out, and window holds it in place).
Frank
(Drive Safely & Responsibly) |
