Old 06-30-2014, 08:06 AM   #15
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Originally Posted by mikeg View Post
great post!
maybe a stupid question...can you over tighten the nut with the wrench turning on it...how do you tell when the riv nut is fully compressed?
thanks
mike
Originally Posted by backtotintops View Post
+1
The bolt your turning will not turn any more, at that point your done, see 1/2 of the nut slides in side the other 1/2 of the rivnut till they meet flush, at that point your done.
2SSRS@Gen5diy is offline   Reply With Quote
Old 06-30-2014, 10:07 AM   #16
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
great post!
thanks
mike
No, you will feel it stop turning
Skylane765 is offline   Reply With Quote
Old 06-30-2014, 10:08 AM   #17
Skylane765
Skylane765's Avatar
It is very easy to make. Just drill a 1/4 hole in the strap and use one 8m nut, bolt and that's it.
Old 06-30-2014, 10:10 AM   #18
Skylane765
Skylane765's Avatar
NO, do not turn the Bolt! Only turn the nut.
I have my tool if some one needs it, we can make them for anyone.
Old 11-14-2014, 09:40 AM   #19
JD-ZL1
JD-ZL1's Avatar
Drives: 2013 ZL1 M6
Send a message via Yahoo to JD-ZL1
riv-nut tool
this is the one I made and used.. my strap was left over from a garage door motor that attaches the door to the chain. 3/16" thick by 14" long the hole in the end was already drilled out and the 8mm bolt fit perfect..
used vise grips to hold the bolt head and the strap with one hand and turn the nut with the other hand.
JD-ZL1 is offline   Reply With Quote
Old 11-14-2014, 09:50 AM   #20
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
I bought the DJ Grilles wickerbill for the ZL1, their rivnut install tool was simply a bolt with two nuts on them and it worked like a charm.
BaylorCamaro is offline   Reply With Quote
Old 11-14-2014, 04:25 PM   #21
tjea
tjea's Avatar
Drives: 2014 1ss 1le Blk/Blk
If anyone wants a source to the commercial tool and rivnuts. Scroll down to see tool link.
http://mdmetric.com/prgde3b.htm
tjea is offline   Reply With Quote
Old 09-14-2015, 05:27 PM   #22
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Ok, so I have a question. I drilled the holes, and the riv nut just slides in. How much force does it take to get it to actually pop in that hole and be secure? Should that riv nut just slide right in after the drilling? I used the 35/64 as it called for.
Tightening the nut on the tool will actually spread it out? It almost seems like the hole is too big.
Help please.
Angela
350 HRSS is offline   Reply With Quote
Old 09-14-2015, 08:20 PM   #23
Skylane765
Skylane765's Avatar
Help please.
That all good, it slides in and you tighten the riv nut with the tool, it expands to hold it in place. We changed the size for later hardware to help you guys out and not have to buy the higher priced tool and the bit to use is more common. we now have 1/4 20 and the our first ones were M8 like the OEM. Like I said in this post and in the directions its better to ream to the size but it will work when you use the riv nut tool.
Old 09-14-2015, 08:32 PM   #24
Skylane765
Skylane765's Avatar
here is a look at what the riv nut looks like pulled.
Old 09-14-2015, 09:18 PM   #25
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Thank you! That pic helps a lot, and means mine should work no problem once i use the riv nut gun. Thank you so much for posting!
Angela
Old 09-14-2015, 09:24 PM   #26
didon1972
Drives: 2014 Z28, 1969 Camaro SS
I just bought a set of hardware for my install from NRG & it comes with the rivet nut tool all for $25
didon1972 is offline   Reply With Quote
Old 09-15-2015, 03:03 PM   #27
Sickness91Z28
Reaper Crew
Sickness91Z28's Avatar
Drives: Blown 2010 Camaro SS
Very cool, have any pics of the hardware installed?
2010 Camaro SS
SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP
Pedders XA Coilovers
Sickness91Z28 is offline   Reply With Quote
Old 09-15-2015, 05:10 PM   #28
didon1972
I'm waiting on the wickerbill to be delivered by Friday. I'll post pics after I install it.
