12-17-2015, 04:15 PM | #1 |
Drives: 2015 Manual V6 1LT RS AGM Camaro Join Date: Aug 2015
Transmission Upgrade
I have a 2015 V6 manual and it is a pretty bad tranny.. 1st and 2nd shifts are real teeth grinders. Would it be worth upgrading that or do you guys know if the new 2016 model V6's have a better tranny?
Thanks! |
12-17-2015, 05:00 PM | #2 |
are you fully pushing the clutch to the floor? there should be no grinding and if there is go to the dealer and have them check it out.
12-17-2015, 05:09 PM | #3 |
I have a 2014 1LS, and no grinding (16,000 miles)
12-17-2015, 05:30 PM | #4 |
Sorry, that was an analogy. It's not actually grinding it's just a little stiff and clunks a little. Could be the driveline slack or something.
I have heard the tranny in the V8's shifts smoother. Should I swap for that one? |
01-16-2016, 05:27 AM | #5 |
The gritos pollo!!!
The cost would be unreasonable, just told some one else the same thing, switch to scheaffers 75/90 and you will notice the difference before the end of the block
______
If you don't stop how can they give you a ticket?-The Big Tuna___ '12 1Ls Camaro; Slp loud mouth I|maganflow x-pipe|Injen long ram intake|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can| '13 Avenger R/T '77 T/A 6.6;, draining my wallet. |
