11-28-2015, 12:48 PM | #1 |
Drives: 2015 Corvette 3LT with Z51 Join Date: Nov 2013
V6 Clutch Kits
Does anyone know if the 2012 RAM clutch kit (part number 75-2105) would work for a 2013 Camaro LS? Their website states 2010-2012 only, but I'm not aware of any transmission differences between 2012 and 2013. If not, does anyone have another clutch kit they can recommend for a V6? It needs to support at least 460 RWHP, but preferrably 550+.
Thanks! |
11-28-2015, 03:54 PM | #2 |
The gritos pollo!!!
Perhaps the flywheel is different? Hopefully ram will chime in here.
______
If you don't stop how can they give you a ticket?-The Big Tuna___ '12 1Ls Camaro; Slp loud mouth I|maganflow x-pipe|Injen long ram intake|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can| '13 Avenger R/T '77 T/A 6.6;, draining my wallet. |
11-30-2015, 12:14 PM | #3 |
In case anyone else comes across this, I called RAM and they confirmed that 75-2105 does indeed work for 2013 V6s.
12-10-2015, 06:12 AM | #4 |
Drives: 2014 Camaro 2LT Deep Magenta Join Date: Apr 2015
How about 2014?
12-11-2015, 08:56 AM | #5 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
They're all the same engine and transmission. I would be surprised if it didn't work 10-15.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
