Vararam
Old 11-28-2015, 12:48 PM   #1
M0dnar
Drives: 2015 Corvette 3LT with Z51
V6 Clutch Kits
Does anyone know if the 2012 RAM clutch kit (part number 75-2105) would work for a 2013 Camaro LS? Their website states 2010-2012 only, but I'm not aware of any transmission differences between 2012 and 2013. If not, does anyone have another clutch kit they can recommend for a V6? It needs to support at least 460 RWHP, but preferrably 550+.
Thanks!
M0dnar is offline   Reply With Quote
Old 11-28-2015, 03:54 PM   #2
Vroom_vroom
The gritos pollo!!!
Vroom_vroom's Avatar
Drives: Like a idiot
Perhaps the flywheel is different? Hopefully ram will chime in here.
______
If you don't stop how can they give you a ticket?-The Big Tuna___
'12 1Ls Camar
o; Slp loud mouth I|maganflow x-pipe|Injen long ram intake
|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can|
'13 Avenger R/T
'77 T/A 6.6;, draining my wallet.
Vroom_vroom is offline   Reply With Quote
Old 11-30-2015, 12:14 PM   #3
M0dnar
In case anyone else comes across this, I called RAM and they confirmed that 75-2105 does indeed work for 2013 V6s.
Old 12-10-2015, 06:12 AM   #4
ShadowYYZ
Drives: 2014 Camaro 2LT Deep Magenta
How about 2014?
ShadowYYZ is offline   Reply With Quote
Old 12-11-2015, 08:56 AM   #5
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
They're all the same engine and transmission. I would be surprised if it didn't work 10-15.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
