Old 09-11-2018, 09:50 AM   #1
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
Recommendations please.... Square Setup
Stock 2013 SS.
Found some wheels I like, only come 10" wide. Can get either a 35 or 23 offset.
Want to go with a square, rotatable setup.
Will 275 40 20s work all the way around?
Asking because the guy on the TireRack site says the most they recommend on the front is a 265.
Thanks for all of your help.
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 09-11-2018, 10:12 AM   #2
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
I would recommend a 20x10 square setup with +35 offset which is what I run. 275/40/20s will fit perfect.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 09-11-2018, 10:21 AM   #3
CamaroJim56
Obsessed
Thanks! What wheels are those on your car?
2016 Hyper Blue 2SS
Old 09-11-2018, 12:42 PM   #4
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I have run 275/40/20 on 20x9 +27mm with the Style 41 (ZL1/1LE) Factory Reproductions replicas. I now have 285/35/20's on there. It's a really good setup IMO. The 285 is borderline too wide for that rim - I got a deal I couldn't pass up and figured I'd try it. I've found no ill effects thus far.
The square setup for a stock SS suspension is a great improvement. In factory staggered trim the car has a significant amount of understeer. Going to a square setup brings the car much closer to a neutral balance and makes the car much more enjoyable in the twisties.
Old 09-11-2018, 03:50 PM   #5
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
Originally Posted by CamaroJim56 View Post
Stock 2013 SS.
20X10 35ET WIT A 275/40 WORKS PERFECT WITH ABSOLUTELY NO MODS REQUIRED/
Keep in mind tirerack is extremely conservative and the team focuses on what a computer tells them, nothing like a full hands on experience from vendors that actually see and touch these cars in person on a daily.
Talk to PK auto design they will get you straight/
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 09-11-2018, 06:18 PM   #6
CamaroJim56
Obsessed
Thank you very much for your reply!
Jim
2016 Hyper Blue 2SS
Old 09-24-2018, 06:23 AM   #7
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
I run 285/35/20 all the way around on a 10" wide rim.
Scott@Bjorn3D is offline   Reply With Quote
Old 09-24-2018, 11:05 PM   #8
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
If you go with a 10" wide wheel you could run a 285/35 or a 295/30. The 1le/ZL1 run a 285/35 on a 10" wheel up front.
Matty Ice is offline   Reply With Quote
