Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 08-20-2021, 04:06 PM   #15
craigk777
craigk777's Avatar
Drives: 2013 Summit White 2SS/RS
Congrats!!
craigk777 is offline   Reply With Quote
Old 08-29-2021, 02:17 PM   #16
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Here they cut down the side so we have the 5ft on the side., then they dropped off some dirt to get the pad level.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-17-2021, 09:12 PM   #17
2SSRS@Gen5diy
Update with cement on the ground.
Old 10-21-2021, 02:37 PM   #18
2SSRS@Gen5diy
Lumber is here and they start framing next week.
Old 10-22-2021, 11:07 PM   #19
xstuntman
Drives: 2012 Victory Red LFX
Am I the only one looking at the overhead shot and the neigbors pool and thinking about building a slide?
xstuntman is offline   Reply With Quote
Old 10-25-2021, 12:32 PM   #20
2SSRS@Gen5diy
That is up hill, some 8 Ft so that will not work, now if my lower neighbor build one i will work on that.
Old 10-25-2021, 02:59 PM   #21
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
when you use the word "yard", somehow I was expect grass. LOL.
Old 10-26-2021, 01:51 PM   #22
2SSRS@Gen5diy
Grass does not do good in the summer, when we get to 124+++ degrees.
Old 11-01-2021, 11:30 AM   #23
2SSRS@Gen5diy
First walls are up, pics to come
Old 11-04-2021, 01:15 PM   #24
2SSRS@Gen5diy
new pic
Old 12-19-2021, 09:41 PM   #25
2SSRS@Gen5diy
Going to start rapping this week. will post new pic when that starts, was thinking of spraying insulation on the side wall its has the sun on it all summer long, that works out to be R7 per in, that works out to R38.5, what do you guys think.
Old 12-20-2021, 07:50 AM   #26
gtstorey
I like insulation even in non HVAC garages. It helps mitigate the temperature extremes. If you are talking about only spraying one wall, I don't know how that will work vs all walls with less insulation.
Old 12-20-2021, 08:12 AM   #27
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Anything to bring down the radiant heat. I closed in the trusses with OSB and put that tinfoil lined foam on a roll on my garage door panels and it made a significant difference even before the AC. I only have a 25k window unit and my wife says it's cold in my garage.
Old 12-20-2021, 11:09 AM   #28
2SSRS@Gen5diy
No i meant all the walls and ceiling will get insulation, but that wall will get the spray in as it R value will go from R19 to R38, that what i meant .
