11-12-2017, 09:33 AM | #1 |
Drives: 2020 RGM ZL1 1LE Join Date: Sep 2011
Disappointed with 1/4 mile performance
So i took my car to the drag strip in Commerce Ga. last friday. Only thing done to my car is the Vortech V3 SI supercharger kit (bought it that way). I was running consistant 12.8s @ 110.8 and after looking through the forums i saw thats what some STOCK cars are running! Although i was taking it easy off the line, i feel as if i should be doing a little better than that. Cars an auto and i let it do the shifting just so i could get a “baseline” run before i continue to modify the car. Can anyone help me out here as to why this is?
2020 Camaro ZL1 1LE Rally Green Metallic
2010 Camaro 2SS/RS (Gone but never forgotten) -FAST LSXR 102 -Vortech V3 SI Supercharger -Pulleys -Shake N Bake Cam (233/248) -ALKY meth injection -TSP 1-7/8” headers -Catless X pipe -NPP w/ M2W -Eibach Coilovers -22" Dub S116 Wheels -Fesler Aero Package -3M matte black wrap |
11-12-2017, 09:41 AM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
you need DR's...for your setup minimum 17's but better would be a 15' conversion...2nd you need a tq conv that has a higher stall...3rd is seat time...takin it easy off the line is where you are losin all of you time...until your 60' is below 2 sec you will be chasin time slips till the cows come home....this will get you started...good luck!
11-12-2017, 09:56 AM | #3 |
Drives: Camaro Join Date: Mar 2013
Ditto on the wheels. I wouldn't waste my money on 15s unless you are over the top on the build and will be chasing 9 second passes. 17s with DRs will be fine, I run 1.40 60 ft with them.
11-12-2017, 11:10 AM | #4 | |
11-12-2017, 11:14 AM | #5 |
Yeah im not trynna dig into 9s.. im only gunna pully down the blower, headers/exhaust, fuel management upgrades, and maybe change to the 3.91 gears. I highly doubt i would be gettin close to 9s
11-12-2017, 11:26 AM | #6 |
Those 22" wheels you have are no good for drag racing.
Pro Stock John has a good thread on here for drag racing wheel/tire setup. http://www.camaro5.com/forums/showthread.php?t=392950 You'll also want to upgrade your rear suspension, toe links/trailing arms to start, to eliminate wheel hop from hard launches.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
11-12-2017, 12:11 PM | #7 | |
btw - as above wheel hop is the enemy and my BMR T/A's and Prothane rear-sub inserts give me ZERO hop....
11-12-2017, 12:41 PM | #8 |
You may want to rethink the 3.91 gears with a supercharger. Normally, NA cars do that swap. I have 3.73 and would probably do better with 3.45 with a supercharger but that size isn't available for the ZL1 diff.
11-12-2017, 10:59 PM | #9 |
Oh dang, i never realized that. I imagine it would be a highway RPM problem?
11-13-2017, 04:36 AM | #10 | |
Drives: 2010 Camaro 2SS/RS Hennessey Join Date: Mar 2017
More or less because the A6 gearing Switching to 3.91 you’d blow the tires off because a supercharger is instant boost, and wouldn’t recover traction till 3rd gear Sent from my iPhone using Tapatalk
2010 Camaro 2SS/RS Hennessey HPE550:
-Ported Cylinder Heads / Hennessey Performance CAI / / redone valvetrain (Hennessey specific) / Hennessey Performance Cam / Longtubes / 160 Degree Thermostat / Savini (Hennessey) matte black wheels, chrome lip (staggered) / Solid engine mounts / Hotchkis F&R Sway bars / UMI Performance Trailing and toe arms / Hotchkis 4pt tower brace / TVS2300 @10psi with cog drive / Aeroforce scangauge / SLP boost gauge / Corsa sport cat back / UMI Performance tunnel brace / Smoked LED tails (sequential) / large fin rear diffuser / Smoked running lights (led) / and more |
11-13-2017, 06:36 AM | #11 | |
waiting at the tree
2010 2SS/RS A6 ZL1 Rims
11-13-2017, 07:31 AM | #12 |
11-13-2017, 09:23 AM | #13 | |
who or how is the car tuned?
11-13-2017, 11:07 AM | #14 |
Exactly! Thats what i figured. (@jrhagen & 102SS) But i bought the car with the supercharger kit originally, previous owner told me it had the tune that came with the kit via SCT handheld.
