10-14-2017, 07:37 AM | #1 |
Drives: 2012 BMW 135i Join Date: Nov 2016
Bleeder screw torque?
Anyone know the correct torque spec for the bleed screws on the calipers? Thx
10-14-2017, 09:22 AM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
prob just a couple of inch lbs...just tighten till snug and then give it a "bump" to lock it...make sure to use a 6 and not a 12 point socket(or wrench) to loosen...avoid rounding the bleeder...do not over tighten! not necessary....good luck!
10-14-2017, 12:26 PM | #3 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
I know that stock SS brembos are 89in-lb for bleeder screws. I don’t see why the brembo calipers on the Z/28 would be any different. Do you use an 11mm wrench on the bleeder screws? If you do then the bleeders are likely the same as the SS brembos so I would imagine that the torque spec is also the same.
