09-21-2017, 12:53 PM | #15 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
09-21-2017, 02:01 PM | #16 | |
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
09-21-2017, 06:08 PM | #17 | |
Interestingly enough the cell phone adapter specs say they will go up to over 700deg.
09-21-2017, 08:33 PM | #18 | |
I think the specified range corresponds to the accuracy specification. Outside of that range I imagine the measuring resolution, and therefore the accuracy are lower as the sensor becomes washed out. That being said emissivity can also affect the measurements. That being the case I wouldn't use the rotor images as a end all measurement, but use it more qualitatively. IE do I see any hot spots on the rotor or caliper that could indicate an issue etc. |
09-21-2017, 08:37 PM | #19 | |
09-21-2017, 08:39 PM | #20 | |
09-22-2017, 08:17 AM | #21 |
I definitely will if I end up getting one. Will need to research more first. And my track season is less than a month away from ending for this year.
09-22-2017, 01:38 PM | #22 |
Drives: None Join Date: Nov 2013
It's good to see that the airbox and ducting remained cool depsite the hot engine
