Vararam
Old 02-27-2018, 12:16 PM   #1
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
LED Brake and Turn Bulbs
Does anyone sell the 3157 LED bulb for the brake and rear turn lights which is just plug and play and doesn't need a resistor?
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 02-27-2018, 02:33 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
well it doesnt "need" a resistor BUT, without the resistor, you will get the "hyperblink" and your car will continually bitch about one of the tailights being out.
you can find the bulb on ebay, amazon, etc.
you can also try
gen5DIY and diodedynamics
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 02-27-2018, 09:01 PM   #3
Cheap Guy
Cheap Guy's Avatar
you can also try
Yeah, that’s what I was trying avoid. I figured someone had a “built-in” solution that does require splicing in a resistor.
Old 03-01-2018, 04:10 PM   #4
davesnever
davesnever's Avatar
Drives: 2010 Camaro 2SS
Looking for something like this? Plug and play!
https://www.ebay.ca/itm/JDM-ASTAR-31...VWBZYa&vxp=mtr
or for a cheaper solution lol
https://www.ebay.ca/itm/2Pcs-3157-33....c100005.m1851
davesnever is offline   Reply With Quote
Old 03-01-2018, 05:55 PM   #5
mma
Drives: 1LE
i bought some resistors off of amazon, no hyperblinks
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
they're kinda cheap, but they work. had 2 break off on me and replaced them
mma is offline   Reply With Quote
Old 03-02-2018, 11:25 AM   #6
Cheap Guy
Cheap Guy's Avatar
^^^^Thanks! I know the individual resistors are fairly cheap, but I may go this route just for convenience sake.
Old 03-12-2018, 01:36 AM   #7
thiwho
Drives: 2012 Camaro 2SS/RS
Do you have to use one for every bulb you replace?
thiwho is offline   Reply With Quote
Old 03-12-2018, 11:01 AM   #8
crazy4camaro
Drives: 2012 RSLT,1979 Trans Am
not for every bulb replaced with led but for directional signal leds I did buy the JDM plugin harness easy and no more hyper flash
crazy4camaro is offline   Reply With Quote
Old 03-12-2018, 12:56 PM   #9
Cheap Guy
Cheap Guy's Avatar
After doing research, I'd probably go with the plug and play harness that was in a post above. The harness is not much more than just buying the load resistor separately.
Old 03-12-2018, 06:48 PM   #10
thiwho
O ok so the front turn signal would need one and the other lights are the turn lights for us so they would need one, but the inner ones would not because they are just brake light.
