06-11-2013, 09:48 PM | #15 | |
Don't elaborate too much, but do u have a semi itemized list of what's done to ur Camaro? U still have stock internals right, but sounds like ur rear end was swapped out, so maybe that should account for part if my question... What is max power I should have with all the major components not being swapped out?
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M 11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M 10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M 10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS) Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM |
06-11-2013, 09:52 PM | #16 | |
Drives: 2010 Camaro Join Date: Feb 2010
As for a list. At this point every single part that can be upgraded has been. And I mean everything. Are you going to be drag racing your car at all? |
06-11-2013, 09:54 PM | #17 | |
06-11-2013, 10:13 PM | #18 | |
Robert
06-11-2013, 10:16 PM | #19 | |
If you're not going to race your car stay at 550 rwhp. After that you'll need major fuel upgrades. Plus the afm crap. 550 is gd for the street. |
06-11-2013, 10:22 PM | #20 | |
Drives: '11 Cammed LS3, '14 Scion FRS Join Date: Dec 2011
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP |
06-11-2013, 10:28 PM | #21 |
100 shot no. The 150 would be close. Maybe slightly bigger injectors. You'd still be under 500 rwhp so youll prob be ok. You'd have to talk to your tuner. Spray it on the dyno and see for sure. Every car is a bit different. You'll have to pull a little timing.
06-11-2013, 10:31 PM | #22 |
Drives: aqua 2ss l99 Join Date: Jun 2009
no blower? likely....
May your exhaust note, sing in harmony with your blower.
06-11-2013, 10:34 PM | #23 | |
I just wanted to make sure 550-570 is an ok range with out expecting anything to fail. I do keep an entire binder log of what's done to the car (down to my very first gas receipt), so I will always know what this csr has cost me haha...
Robert
06-11-2013, 10:36 PM | #24 | |
You should stop keeping track of the cost. It's only evidence for your wife to use against you!! |
06-11-2013, 10:42 PM | #25 | |
Haha, shes not worried about the cost (not that we'er rich or anything by any means ha), heck she's the reason it's supercharged lol. She just won't let me take it to the track (yet!)
Robert
06-11-2013, 10:53 PM | #26 | |
06-11-2013, 11:09 PM | #27 |
On the phone all I see is the first line. Looks like you have springs. If you're at 476 now and spray a hundy you'll need at least a bap. Most would go zl1 pump. If I'm replacing the pump I'd install a double pumper and be done with it. Fuel and tune are the most important things in regards to engine safety/longevity. Address your fuel system before spraying.
Sorry for the misunderstanding. |
06-11-2013, 11:44 PM | #28 |
OP being you have a E-forse I would just go with the smaller pully and a good tune. That L99 should be 525+rwhp but with a ton of low end torque. Which is where all the fun is on the street. It will "Feel" like it has a lot more HP then it does.
Like Supercharge SS said he was in 9's with stock suspension. My buddy's L99 was Not very impressive Until he got a tune for the transmission and the stall converter. Now that thing is very Impressive. So my vote for ya 1.) Get the boost up from the 5.5 range to 8 ish. 2.) Get a good tune that Includes the transmission. 3.) If you want to take off like a jack rabbit get a stall it Really wakes up those A6. |
