Old 04-18-2024, 08:38 AM   #1
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
Wheel Backspacing?
I see all of the Camaro Wheel specs like diameter, width, offset, and bolt pattern, but what is the BACKSPACING on the stock 20x8 and 20x9 wheels?
I am looking to buy a set of custom Snowflake Wheels for my Camaro Trans Am Conversion, and am having issues finding sources (other than the megabuck Forgeline's TA3 in the pic) that make them in 20", and need backspacing info to get them built correctly.
hesster is offline   Reply With Quote
Old 04-18-2024, 10:26 AM   #2
Tommi
Tommi's Avatar
Drives: 2010 Camaro SS manual
Here is a calculator you can use to convert backspace to offset and vice versa.
https://tireswheelsdirect.com/wheel-...ce-calculator/
And here are the calculated values for the stock SS wheels:
Front: 20x8 Offset: 35 Backspacing: 5.9
Rear: 20x9 Offset: 40 Backspacing: 6.6
Edit: remember to post pictures when you get the wheels installed!
2010 Camaro SS, LS3 + 6spd manual.
1975 Volvo 242, 357SBC + 6 spd manual.
1978 Blazer offroader with LS1, 1-ton axles.
Tommi is offline   Reply With Quote
Old 04-18-2024, 10:34 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Well, I did find this about the 9 inch OEM wheels..
https://www.bing.com/search?q=2011+c...ecs&FORM=QSRE4
Old 04-18-2024, 10:38 AM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Some more info on the OEM wheels that was posted on the forum by 9ball, who used to be a member back in the day..
https://www.bing.com/search?q=what%2...&ghacc=0&ghpl=
Old 04-18-2024, 07:06 PM   #5
SlowLS1
SlowLS1's Avatar
Drives: 2010 Camaro SS , 2011 Colorado LS1
This is what I found on several sites...
SlowLS1 is offline   Reply With Quote
Old 04-19-2024, 06:59 AM   #6
hesster
hesster's Avatar
Thanks all - just wanted to be absolutely sure a custom made wheel will fit as they usually are not returnable.
Old 04-22-2024, 12:25 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Ahh bro, that's lookin better all the time!
