dave@hennessey
Old 01-29-2015, 09:59 PM   #15
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
I haven't seen this with the conversions we have done.
BLACK10 is offline   Reply With Quote
Old 01-30-2015, 09:41 PM   #16
Bo White
Bo White's Avatar
I wouldn't know personally. Just went with my builders recommendation.
Totalled:
Old 02-07-2015, 05:24 PM   #17
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
So what are doing for a driveshaft loop?
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian
LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads
ProCharger F1-X
Nitrous Outlet Direct Port
Fore Innovations Triple Pump on E85
Alky Control Meth Injection
ProEFI ECU
Stainless Works 2" Headers with Corsa 3" Exhaust
RPM 4l80e with Jakes Transbrake
BMR Everything with 15" Conversion
Zl1 Front Brakes & Carlyle Racing Rear Brake Kit
Weld Wheels
moiy1983 is offline   Reply With Quote
Old 07-03-2015, 05:12 PM   #18
williamp78
williamp78's Avatar
Drives: 2011 2ss blk/wht strp
Anyprogress yet? I am about to start my 4l80e swap from this m6. I will be going full manual Valve body. Anything needed for the speedo to work?
2011 2ss black/wht stripes
"CAM only"
https://www.instagram.com/w_j_p_boss/?hl=en
williamp78 is offline   Reply With Quote
Old 07-06-2015, 03:41 AM   #19
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
If you don't hook anything at all up to the vss. It will read off the vss. The problem is it throws a cel. If you can live with the cel you don't need to hook anything up. If you want the cel off hook up the speedo output of whatever controller you are using to pin 71 in the ecm.
The latter may seem simpler but my tci ez tcu was reading 4mph at 40 and 6mph at 70. Everything was way off so I disconnected it to read off the speed sensors.
ttshovel is offline   Reply With Quote
Old 07-06-2015, 09:16 AM   #20
pancherj
Drives: 2010 Camaro SS
Took mine for a ride yesterday and have the same issue (US Shift hooked to pin 71). There may be some settings in the controller software to manipulate the VSS signal. As soon as I diagnose my mechanical issues, I will look into this.
pancherj is offline   Reply With Quote
