Old 03-31-2018, 07:23 PM   #1
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
Spark plug wire heat sleeves
Anyone use spark plug wire heat sleeves after putting headers on? What kind did you use?
tnspd is offline   Reply With Quote
Old 03-31-2018, 07:54 PM   #2
brettman
brettman's Avatar
Drives: 2016 Camaro SS
Yes, you need them, or wires will burn. just do a search, buy some good ones.
Also you can remove the coil cover. Move the coil wire boot back to pull the wire further away from the header tube.
2016 Camaro 1SS, Red Hot, K&N Blackhawk intake, Whipple Supercharger, 3.125 pulley, Kooks 2" long tube headers, High flow cats, secondary cats delete, Mishimoto catch can, P3gauge, Lots of dress-up crap that don't make it go any faster.
Car Journal http://www.camaro6.com/forums/showthread.php?t=490975
SC build http://www.camaro6.com/forums/showthread.php?t=492656
Drive, Ride, Fly It Like You Stole It
GO BIG OR GO HOME
brettman is offline   Reply With Quote
Old 03-31-2018, 08:46 PM   #3
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
I use DEI titanium sleeves.. No problems.
djfury05 is offline   Reply With Quote
Old 03-31-2018, 10:41 PM   #4
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Msd is what mine are
Old 04-01-2018, 09:27 AM   #5
parbreak
Drives: 2017 50th Camaro SS
DI Titanium
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 11-05-2019, 05:25 PM   #6
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Old Thread Resurrected Spark Plug Heat Sleeve
So is this what most of you are using?
https://www.summitracing.com/parts/dei-010475
Or this?
https://www.summitracing.com/parts/dei-010542
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 11-05-2019, 05:43 PM   #7
enzia35
Drives: '16 Garnet Red 1SS
Prolly the second, the first seems to be a whole roll and you cut to fit.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 11-05-2019, 06:25 PM   #8
SanDMaN2091
SanDMaN2091's Avatar
Drives: 2016 Camaro SS A8 NPP
Heatsheild products has a good set.. I've had mine on for over a year no problems. Side note: make sure you have cut loose and re ziptied wire harness under coolant tank... that's a major problem waiting to happen If not.
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
LPE Ported/Polished 95mm LT5Throttle Body,
PRAY Ported MSD Intake Manifold,
SP Coated TSP 1 7/8" Catlless Longtubes
Hooker BlackHeart Cat-Back,
Mishimoto Catch Can (Which always has some nasty in it)
Instagram@Weapon_6
SanDMaN2091 is offline   Reply With Quote
Old 11-05-2019, 08:46 PM   #9
OVRKLL
Thanks for the suggestions!
Old 11-06-2019, 06:20 AM   #10
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
Got about 10k miles on 2" tsp headers with factory wires and no sleeves. No issues. Not 100% any of that stuff is actually needed...
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 11-06-2019, 09:10 AM   #11
enzia35
Peace of mind has a price...It's evidently only $60 or so, lol. I will run them when I get headers.
'16 Camaro 1SS
'18 Miata GT
Old 11-06-2019, 06:17 PM   #12
OVRKLL
Good to know, especially for those that choose not to spend the $$ on sleeves, but on other things.
However, I feel it's kind of like Flood, Hurricane, Fire etc. insurance.
Not a 100% needed, but good to have when you do need it.
For me, I'd rather be safe than sorry even if we're only talking spark plug wires.
My Kooks will be coated as well for that extra Heat insurance.
Old 11-08-2019, 06:04 PM   #13
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
I have the individual summit ones and they are good quality and a decent price.
Dan82679 is offline   Reply With Quote
Old 11-09-2019, 09:25 AM   #14
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
Very interesting this jus happened to my boys SS. The #5 plug wire seem to be the only close to the Kooks headers. He purchased one sleeve after he fried his with a boot sleeve from advanced Auto for 12.99
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
