TireRack
Old 01-05-2016, 02:53 PM   #1
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
Swapping to 3.45 gears on supercharged L99
I've got a 2013 SS with an SLP TVS2300, still using the pulley that came with it. It's a daily driver and occasionally gets to the track (1-2 times per year).
I'm very happy with the way it drives, but have appetite for a bit more kick right off the line. Was wondering whether switching to 3.45 gears would do the trick? Have read higher than that (was also looking at the GM 3.91s) on an FI L99 is too much gear.
Also open to any other suggestions of next mods to add instead. Not really looking to add much more rwhp at this point (can maybe push another ~40-50 without having to do many other modifications I think). Though trying to keep mods to those approved in California (so no cats, LTs, cams, etc)
Thanks for any suggestions!
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 01-05-2016, 03:25 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You are only looking at something like a 5% torque advantage going from 3.27s-3.45s. You will get a lot more out of a torque converter. Or better yet, do both!
Old 01-05-2016, 04:08 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
I had 3.91 and changed to 3.45 but if I had my original 3.27s, I would keep them.
With the 3.45s, 1st and 2nd spin city at my RWHP... What RWHP are you?
I agree, not a big enough change from 3.27 to warrant the cost.
Now a posi mod.... ;o)
-Don
747 RWHP 794 RWTQ
Old 01-05-2016, 04:13 PM   #4
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
If you want the feel good go 3.91.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 01-05-2016, 04:32 PM   #5
hammdo
hammdo's Avatar
Mr. Nasty, I'm assuming you're an M6?
That would makes sense on the manual using 3.91, autos are a different story, 3.91s are crazy in an auto ;o)...
-Don
747 RWHP 794 RWTQ
Old 01-05-2016, 05:02 PM   #6
Mr. Nasty
Mr. Nasty's Avatar
AUTO with the 4l80 been running the 3.91 For 3 years with it. If they made 4.11 that would not come apart I would run them.
I have friends in the 500rwhp with the 6l and running 3.91 rear gear
Old 01-05-2016, 05:47 PM   #7
hammdo
hammdo's Avatar
4l80, that works!
-Don
747 RWHP 794 RWTQ
Old 01-05-2016, 06:15 PM   #8
HAMBO
HAMBO's Avatar
Thanks for the tips everyone! Sounds like going to 3.45 isn't worth that much, but then again, wouldn't a 5% boost in torque be noticeable? With over 400 lb ft, that would be equivalent of adding +20 lb ft. Not a noticeable bump?
Also sounds like 3.91 on stock L99 transmission would be too much.
hammdo - would you mind elaborating on the posi mod? Sorry, still new to a lot of this.
Thanks!
2013 AGM 2SS/RS
Old 01-05-2016, 07:50 PM   #9
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
I run 3:45 auto at 825 rwhp
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 01-06-2016, 09:14 AM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
3.45 is our go to gear for forced induction L99 cars.
We developed the posi mod back in 2010 when we went to the first Camaro 5 event and noticed many of the cars doing 1 tire burnouts.
Upon inspection we found that GM put together a wimpy posi clutch combo.
JRE posi mod comes with new clutches, preload spring and instructions to give you a tough posi that won't do 1 tire burnouts.
http://www.jreperformanceparts.com/2...-posi-mod.html
During this process we also developed our Billet cap kit because we found that the factory main caps stretch out and cause gear failure or noise.
http://www.jreperformanceparts.com/jre-billet-caps.html
We offer fully rebuilt and upgraded exchange Differentials built to your needs
http://www.jreperformanceparts.com/2...des-labor.html
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-06-2016, 09:54 AM   #11
SRTKILLER
SRTKILLER's Avatar
Drives: 2009 Cadillac CTS-V
A converter will make a big difference out of the hole for you. That's what I would do over the gears or do both.
SRTKILLER is offline   Reply With Quote
Old 01-06-2016, 11:21 AM   #12
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Agree on the converter, but do your research on stall speed ect. On my 02 a4 z28 with a converter I dropped .5 seconds off my quarter mile time and it just made the car more fun
Moreair1 is offline   Reply With Quote
Old 01-06-2016, 12:36 PM   #13
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
I'm still running my 3.27s
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 01-06-2016, 09:36 PM   #14
hammdo
hammdo's Avatar
Ted.
This is what I was referring to. GPI did mine. As I noted, first and second are a lot of spin at my RWHP level... Stock converter...
-Don
747 RWHP 794 RWTQ
