Old 10-17-2012, 11:51 PM   #15
Originally Posted by yotaman96 View Post
No tune needed. I don't think anyone has found the max limit yet. I have one with a BAP and its fine at 630 rwhp. Hoping for around 670 next time.
So it regulates on it's own? How does it keep the 60lbs.?
Old 10-17-2012, 11:54 PM   #16
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
The fuel pressure regulator isn't on the pump, so pressure should stay the same. The ZL1 pump just allows more volume if needed.
Here's what I just found.
Pulse-width modulated, eliminates need for conventional pressure regulator
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 10-17-2012, 11:54 PM   #17
KRich2587
KRich2587's Avatar
Drives: 2014 Summit White 1LE
Pulse width modulation computer sends a duty cycle to the pump that's how the pressure is controlled
Posted from Camaro5.com App for Android
KRich2587 is offline   Reply With Quote
Old 10-18-2012, 12:01 AM   #18
So what tells the pump to up the power to keep the pressure up at WOT?
Must be a default setting that isn't changed in a tune.
Old 10-18-2012, 12:02 AM   #19
Ok. So it's a standard and unchanging process.
Old 10-18-2012, 12:08 AM   #20
yotaman96
yotaman96's Avatar
I'm not sure exactly how it works, I just know it does. lol Keeping all things the same except for swapping to the ZL1 pump, no tune would be needed.
2002 Trans Am
Old 10-18-2012, 02:25 AM   #21
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
I am just a hair under 650rwhp now and I'm just running the ZL1 pump, no BAP. Fuel pressure is perfect and the new injectors aren't even having to work for it. I think they were at 53% duty cycle or something crazy like that.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 10-18-2012, 05:36 AM   #22
usmcjlp
Drives: 2SS/RS LS3 RJT
I have a whipple, cam and headers with 4.11 gears. I was looking at the aeromotive fuel pump. If I am going to pay the labor to install the pump, would it be better to go ahead and pay a little more to get a stronger pump? Or is the OEM set up more than enough and better quality?
Should I also swap my fuel injectors? I have the injectors that came with the kit. Thanks in advance.
usmcjlp is offline   Reply With Quote
Old 10-18-2012, 06:22 AM   #23
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
You add the ZR1 MAP sensor and it tells the ECM when you are in boost which increases the PW to the pump. I have the BAP also.
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 10-18-2012, 07:40 AM   #24
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
I am at 665 rwhp with the ZL-1 fuel pump and the BAP off. Fuel pressure is perfect. I am also glad I installed an access door under the rear seat. If I ever have a problem or want to up grade my fuel pump it will only take 15 minutes.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 10-18-2012, 08:43 AM   #25
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
Would you be able to take a few pics of the access door? After changing out my tank twice, I would gladly cut the hole for easier access. Make a 5-6 hour project into 15 minutes sounds great....
Thanks.
AngelSpeedFreak is offline   Reply With Quote
Old 10-18-2012, 09:22 AM   #26
MANNYS2SS/RS
Thanks.
Angel this is not for everyone, but I am so glad I did it to my car. With the tool it takes me 15 min to replace the pump.
Old 10-18-2012, 09:34 AM   #27
epstein
Drives: SS/RS
Send a message via AIM to epstein
hmmm with some spray foam after your done around the seam or sound deadner like most of us have done in our vehivles This is very conceivable
epstein is offline   Reply With Quote
Old 10-18-2012, 09:54 AM   #28
MANNYS2SS/RS
I seal it with black latex caulk, once the seat is on you don't see or hear anything.
