Roto-Fab
Old 07-30-2015, 06:44 AM   #1
Zeus95
Zeus95's Avatar
Drives: IOM 2010 - 2SS/RS
Brembo Caliper Bolts
Took my Calipers apart to have them Powder Coated. Stripped the head off one of the 4 Star Headed bolts. OOPPSS !! Then I find out my dust boots are all torn up and burnt. So I ordered new boots and seals. But I can't find a replacement bolt. Called GM and they say the 4 bolts come with the caliper as a kit. can anyone help ? Thanks all !
2010 2SS/RS IOM Upgrades: Fastlane CAI / SLP II Loudmouth axle back / V Max Ported TB / Kook's Step Long Tube Headers / High flow cats / Straightline Tune / BMR front & rear sway bars / Hotchkin End Links / Hurst Short Throw. LG ZR28 Wheels 1 of 2 sets made. Pfadt trailing arms / Diff Bushings & Sub Frame bushings / 1LE Axle & Hubs.
Zeus95 is offline   Reply With Quote
Old 07-30-2015, 07:28 AM   #2
Synner
Drives: cars
GM was dropped on their head as a child.
4 ea 11570788 front
4 ea 11515781 rear
Synner is offline   Reply With Quote
Old 07-30-2015, 09:16 AM   #3
Zeus95
Zeus95's Avatar
4 ea 11570788 front
4 ea 11515781 rear
thank you !!!
Old 07-30-2015, 09:20 AM   #4
Zeus95
Zeus95's Avatar
I just looked it up, that's not the one I need :(
Old 07-30-2015, 09:57 AM   #5
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Are you asking for a banjo bolt part number for the brake line?
Old 07-30-2015, 01:27 PM   #6
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
He's looking for the bolts that hold the caliper halves together. He split them for powder coating.
bannonm is offline   Reply With Quote
Old 07-30-2015, 01:31 PM   #7
Zeus95
Zeus95's Avatar
Not sure Justice Pete. Each Caliper is actually 2 pieces. they are held together by 4 bolts. They have star heads that face to the inside of the car.
Old 07-30-2015, 01:36 PM   #8
Zeus95
Zeus95's Avatar
2nd Pic
Old 07-30-2015, 02:21 PM   #9
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
That might be a tough one to find, i'm sure GM buys the calipers from Brembo already put together so I doubt they stock those bolts separately.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 07-30-2015, 06:18 PM   #10
Synner
Drives: cars
Pull the bolt and measure the threads, you should be able to get a flange bolt of the same thread size/pitch. The moral of the story is you don't need to split the calipers to powdercoat them, thats why I thought you were talking about the standard mounting bolt.
Old 07-31-2015, 06:42 AM   #11
Zeus95
Zeus95's Avatar
I guess my powder coater was being too cautious. But I did find my dust caps were all torn and burnt, so I'm glad I took them apart and found the problem.
Thanks guys !
Old 08-01-2015, 09:54 PM   #12
CAP'N B
Cajun Mariner
CAP'N B's Avatar
Drives: 10 Camaro SS/RS 15 Camaro Z/82 AGM
BAnjo Bolts
I'm doing the CTSV brake upgrade on the front, and I broke a banjo bolt, I could use the part number., Actually I need the bolts by tueday or it's cancel fest
'10 Camaro 2SS/RS Red Jewel VVTLS3/A6
'15Camaro Z/28 Ashen Gray
CAP'N B is offline   Reply With Quote
Old 08-04-2015, 06:12 AM   #13
Zeus95
Zeus95's Avatar
I'm still looking, I'm gonna have to measure and see if I can find a replacement. can't believe that won't/Don't sell these separate.
Old 10-27-2015, 02:19 PM   #14
2011WhiteSS
2011WhiteSS's Avatar
Drives: 2011 White 2SS
Update?
Did you find any of these bolts?
2011WhiteSS is offline   Reply With Quote
