Old 11-21-2014, 02:19 PM   #1
pdiddy
Drives: 2011 2SS
what rpm at 75 mph
Can someone with a M6 and stock gears 3.56 I believe tell me what rpm they are at in 4th gear going about 75 mph thanks
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 11-21-2014, 02:34 PM   #2
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Stock gears are 3.45
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 11-21-2014, 03:04 PM   #3
pdiddy
Drives: 2011 2SS
That gear than lol couldn't remember wat stock was I replaced them wen I got the car
Old 11-21-2014, 04:07 PM   #4
pdiddy
Drives: 2011 2SS
Anyone ??? Lol I know someone driving there camaro can tell I don't condone texting and driving however using a forum and driving is perfectly okay... Jk
Old 11-21-2014, 04:21 PM   #5
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Assuming stock tire height it should be 3029 RPM.
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 11-21-2014, 04:28 PM   #6
pdiddy
Drives: 2011 2SS
Hmmm
Old 11-21-2014, 04:30 PM   #7
pdiddy
Drives: 2011 2SS
Thx if anyone else can confirm great I am debating on a turbo 400 and want to see where I will be on rpm the few times I get out on the highway
Old 11-21-2014, 05:40 PM   #8
GretchenGotGrowl
I am pretty sure 4th in the t6060 is not the same as any gear in the t400. If you mean the TH400 in the 3rd gen Camaro then it is 1.0 in 3rd just like 4th in your transmission. You need to just google rpm gear ratios and use one of the calculators.
Old 11-21-2014, 06:03 PM   #9
Vroom_vroom
The gritos pollo!!!
Vroom_vroom's Avatar
Drives: Like a idiot
what rpm at 75 mph
^ it should be close. There is no od in a turbo trans so 4th is a 1:1 along with 4th in a t6060 beings a 1:1. 5th and 6th on the the od gears. It will be a a bit off though due to slop on the torque converter compared to the clutch.
Sent from the desert.
______
If you don't stop how can they give you a ticket?-The Big Tuna___
'12 1Ls Camar
o; Slp loud mouth I|maganflow x-pipe|Injen long ram intake
|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can|
'13 Avenger R/T
'77 T/A 6.6;, draining my wallet.
Vroom_vroom is offline   Reply With Quote
Old 11-21-2014, 06:40 PM   #10
pdiddy
Drives: 2011 2SS
Yes I am talking about th400 and the 1-1 gear so fourth in a tr6060 will get me an idea on where I would be that's he point of my post didn't know there was a calculator thx
Old 11-21-2014, 07:10 PM   #11
Bo White
Bo White's Avatar
70 on 295/30/22 tires is 2900-3000
Totalled:
Old 11-21-2014, 07:21 PM   #12
James720SS
James720SS's Avatar
Drives: 2010 SS
Hey Bo, Did you do your th400 swap yet?
Polished ECS Novi 1500. Night Fury cam. Alky duel nozzle meth with trunk mount kit. LT Dyntech1 7/8 headers without cats. LPE Twin Fuel Pump. BAER slotted and drilled rotors. BMR rear cradle bushings. Pfadt rear trailing arms. BMR sub frame connectors.Chrome ZL1 Replices front 20x10 rear 20x11 with 275/40/20 Vredestein front 315/35/20 Vredestein rear.720RWHP and 648RWTQ.
James720SS is offline   Reply With Quote
Old 11-21-2014, 07:42 PM   #13
pdiddy
Drives: 2011 2SS
Thx bo
Old 11-21-2014, 07:56 PM   #14
Bo White
Bo White's Avatar
Next month. I'm off 2 weeks.
Totalled:
