AWE Tuning
Old 05-01-2017, 08:28 AM   #1
dcosta
dcosta's Avatar
Drives: 17 ZL1 6M
Rev Limiter hits at 5k to 6k in first and second Gear 1600 mile mark
I have a 2017 ZL1 6speed Manual and I just hit 1600 miles and wanted to see how this thing pulls from first to second gear and the rev limiter is all over the map,sometimes it cuts the car off at 5100 rpm and at 6000 rpm.
When you down shift into second gear and floor it it will sometimes hit 6500 but will hesitate at 5100 rpm most of the time.
Someone said something about a air filter problem??
Not really sure I believe that could be it but who knows.
I race Super Stock Race cars and work on cars for a living so I do know how to test this car in all driving modes.Just starting to get into any info anyone has on this.
I have tested in all driving modes it does the same thing it just cuts the car off at different rpm's.
Didn't get to third gear yet..
DCosta9
dcosta is offline   Reply With Quote
Old 05-01-2017, 08:32 AM   #2
Infern0
Bring It
Infern0's Avatar
Drives: In Between
I have an M6 as well but haven't experienced the same yet. Subscribed for the info.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 05-01-2017, 09:22 AM   #3
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Do a search, another guy is having the same problem, dont think there was a fix or the op didnt post the fix.
-bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 05-01-2017, 09:39 AM   #4
dcosta
dcosta's Avatar
Drives: 17 ZL1 6M
-bobby
Yeah I have been checking that post and he hasn't replied back yet.
DCosta9
Old 05-01-2017, 11:10 AM   #5
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
I had the same thing happening. Engine just completely cuts power while I was trying 0-60 runs after break in. Usually around 5000-5500 rpm, but before 6500 redline. They think it is a air filter issue. I'm getting replacement today. I will update when resolved. Good luck!
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 05-01-2017, 11:10 AM   #6
pkincy
pkincy's Avatar
Drives: 2016 Corvette Z06, 2018 ATS-V
It would seem easy to check. Pull the filter and try again.
Perry
16 SharkGrey A8 Corvette Z06
18 Cadillac A8 ATS-V
pkincy is offline   Reply With Quote
Old 05-01-2017, 11:14 AM   #7
Sooner Cole
I am getting the filter today. The problem is that it doesn't have the problem every single time. It is random. They seem the thing it has to do with humidity?
19 ZL1-1LE A10
Old 05-01-2017, 12:32 PM   #8
pkincy
pkincy's Avatar
If the filter is collapsing due to pressure drop, I would expect humidity would have little to do with it. I still suggest making a few runs (not in a sandstorm obviously) without any filter.
Perry
Old 05-01-2017, 12:40 PM   #9
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Nope
Old 05-01-2017, 12:49 PM   #10
dcosta
dcosta's Avatar
Drives: 17 ZL1 6M
Just took for test drive without and it's better a little doggy without but still shut down twice but also two runs did fine..
Sometimes you just have to try things like this ..
DCosta9
Old 05-01-2017, 01:01 PM   #11
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
If the A10 does not do this and they use the same filter it my not be that.
2SSRS@Gen5diy is offline   Reply With Quote
Old 05-01-2017, 01:21 PM   #12
pkincy
pkincy's Avatar
If you did 4 runs without the filter and 2 were fine and 2 shut down, it certainly is not the filter causing the problem.
We really need to combine these 2 threads on the same topic.
Perry
Old 05-01-2017, 01:49 PM   #13
dcosta
dcosta's Avatar
Drives: 17 ZL1 6M
Correct..I don't think it is the filter.
DCosta9
Old 05-01-2017, 02:39 PM   #14
Sooner Cole
Well, that's disappointing. I was hoping we had solved the issue. There are a few people on here who have had issues with fan belt rubbing on wires and causing similar issues. Do a search and see if you can find it. Good luck and let us know because I have the exact same issues!
19 ZL1-1LE A10
