Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 09-20-2022, 08:57 PM   #1
Kings2010
Kings2010's Avatar
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins
BTR PDS STAGE 1 And 2 torque Cam
I'm looking at the above cams and wondered if anyone has personal experience with either of them?
I have had cars with big lopey cams before and I'm kinda done with that. I just want a cam that makes good power with excellent street manners.
I've also considered the ls9 cam.
There's just not much info or first hand accounts that I can find on the above cams especially the stage 1.
Thanks
Kings2010 is offline   Reply With Quote
Old 09-21-2022, 02:26 PM   #2
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I have had lopey cam cars before and I'm kinda done with that. I just want a cam that makes good power with excellent street manners.
There's just not much info that I can find on the above cams especially the stage 1.
Thanks
https://briantooleyracing.com/btr-pd...-camshaft.html
sounds like a great cam from the specs. I want one.
silversleeper is offline   Reply With Quote
Old 09-22-2022, 11:47 AM   #3
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
I've had the BTR 2 for almost 2 1/2 years now and love it. For street I would not go any higher...it's as choppy as I want for street use. The most important thing is a really good tune for an experienced tuner.
JB'sZL1 is offline   Reply With Quote
Old 09-22-2022, 08:49 PM   #4
Kings2010
Kings2010's Avatar
Is it the stage 2 torque or the old stage 2?
Edit:. The new stage 2 torque Cam is on a 113lsa
The older stage 2 is on a 122+6 lsa
Old 12-14-2022, 11:00 PM   #5
Kings2010
Kings2010's Avatar
No one?
Old 08-02-2023, 07:17 PM   #6
Kings2010
Kings2010's Avatar
Bump
Old 08-03-2023, 06:19 AM   #7
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I run the older stage 3 PDS can and it's fine for a daily driver. Not really sure how the specs compare to the newer versions.
larry_g is offline   Reply With Quote
Old 08-23-2023, 12:09 AM   #8
Kings2010
Kings2010's Avatar
Ttt
Old 11-27-2023, 01:02 PM   #9
TopDawg_43
Drives: 2014 Camaro ZL1
I run a BTR Stage 3 Torque cam. And I love it. It's very easy to drive in traffic. It does not take a lot of gas to get the car moving. The only time it gets kinda weird is if I'm just letting the car roll, while in gear. The loop does make the car lurch back and forth. Other then that, it's smooth sailing.
https://www.tiktok.com/t/ZT8mHnwsH/
TopDawg_43 is offline   Reply With Quote
