AWE Tuning
Old 11-23-2017, 08:58 PM   #1
POINTBY
Drives: 2020 ZL1 1LE
ZL1 1LE Nut/Bolt Check
For those of us that need to do a nut/bolt check I thought I would make a thread (and this should become a sticky) for us to have all the torque specs for all suspension and frame nuts/bolts under the car so that we may check them for proper torque before a track event and paint pen them.
Do any of you have a complete list of all nuts/bolts and required torque you can share?
Okay, I'm going to start a list below. Please feel free to add post additional torque specs. I've been unable to find all torque specs for front and rear suspension online. So it looks like I'll have to purchase a service manual set for the car.
1. Front strut top mount bolts = 21.4 lb ft
2. Front strut spring seat = 7.4 lb ft
3. Rear sway bar end link = 32 lb ft
4. Whee nut torque = 140 lb ft
5. Engine oil drain plug = 18 lb ft
6. Rear diff drain/fill plugs = 24 lb ft
POINTBY is offline   Reply With Quote
Old 11-23-2017, 11:35 PM   #2
67Builder
White knuckled & smiling
67Builder's Avatar
Drives: '17 ZL1 AKA Perfection!
All I know is the first time I heard the lug nuts were 140ft lbs I had to pick my jaw up off the floor.
2017 ZL1 A10 CFHood PDR NAV NFG - Order # VCSDRJ
TPW -
3/6/2017 VIN - 1G1FK1R62H0192950
6000 - 04/05/2017 - Delivered!
67Builder is offline   Reply With Quote
Old 11-24-2017, 09:11 AM   #3
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Are there known issues of bolts coming loose...?
seanblurr is offline   Reply With Quote
Old 11-24-2017, 09:15 AM   #4
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
I must have missed that. Where is it written that the lug nut torque is 140?
tnspd is offline   Reply With Quote
Old 11-24-2017, 09:57 AM   #5
DangerZL1
Drives: 2023 Black ZL1 Auto
From the owner's manual....
DangerZL1 is offline   Reply With Quote
Old 11-24-2017, 10:24 AM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Attachment 908264
this data is for the SS as the ZL1 engine oil capacity is 10qts.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 11-24-2017, 10:29 AM   #7
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
That's strange. My SS was 10qts, so where is that image from? ha.
Old 11-24-2017, 10:41 AM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
No idea. Nothing in the 2017 manual is listed as 8qts...
Gunkk is offline   Reply With Quote
Old 11-24-2017, 11:20 AM   #9
POINTBY
Any car can work bolts loose when tracked hard.
Old 11-24-2017, 11:32 AM   #10
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
I recently retorqued my wheels on my ZL1 and found out that on all 4 wheels 3 out of 5 lugs turned like the stud was not seated properly. I torqued all to 140. All the others clicked ao I figured those were good. I doubt GM has corrected these issues since they have been going on since the release of the 6G.
KLR ZL1 is offline   Reply With Quote
Old 11-24-2017, 11:50 AM   #11
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
To be honest I'd be more worried about things coming loose on the street considering how bad NVH can be with the hard mounts. I don't believe this is as common as some may think though, I've been around race cars for years and it's never been an issue. With that said, it's not a bad idea to have a list of specific torque values on hand especially items related to alignment.
Old 11-24-2017, 11:59 AM   #12
POINTBY
Ladies, enough of your opinions.
Let’s build a list with torque values already!
Old 11-24-2017, 12:00 PM   #13
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Ladies?
Old 11-24-2017, 12:50 PM   #14
POINTBY
Ladies?
We are now on post #14 and all we have established is wheel lug torque (which is the easiest and most common).
I think all of our time is much more valuable, mine sure is. I don’t have the time to sit on this forum and correspond all day.
I’ll just search and build my own sheet of all nuts/bolts before I read opinions on this thread.
Cheers!
