06-22-2023, 01:26 PM | #1 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
anti-slip pully/belts?
did a search and came up with nothing concrete. Now that I can address my concern of the P0300 issue (where I'll need to start) my next step is to address obvious belt slip. during a hard pull on the highway I can clearly feel that there is belt slip. right now, I am on the belts that Magnuson sent me, I do however, have a 1 smaller pully down 95mm.
-looked at Magnuson's site and not really knowing where to go/need. -thanks for your advise.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
06-22-2023, 01:43 PM | #2 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
Griptech pulleys are really good. Rpm/Gates Green belts is what everyone uses for belts. You probably just need a smaller belt considering you went down a pulley size. Shouldn't be getting any belt slip with a pulley that big.
06-22-2023, 03:21 PM | #3 |
HYPER SS
Great thanks!
Ordered: 1/15/2016
06-22-2023, 03:55 PM | #4 |
ZPE makes the griptec stuff so you can just order right from them instead of paying a markup somewhere else:
https://www.zpegriptec.com/ I’ve had great luck with Dayco belts. The one time I didn’t use it, the belt broke FWIW. Many of theirs are American made too. But Gates is obviously great too. Keep in mind most people see 1.0-1.5 pounds of additional boost going from a regular pulley to a griptec. Something to keep in mind if your fueling is on the edge.
06-22-2023, 04:59 PM | #5 |
Used to own a ZL1
06-22-2023, 08:47 PM | #6 |
They grip the belts…thus the name my man. The belt contact surface feels like 2000 grit sandpaper. Smooth enough so that there’s no belt damage (obviously) but the reduction in belt slippage is dramatic, especially at more aggressive pulley combos. I couldn’t imagine trying my combo without it…
06-22-2023, 09:19 PM | #7 | |
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 06-24-2023 at 08:48 AM. |
06-22-2023, 09:53 PM | #8 |
Are you sure that’s the belt your using…? That’s only a 6 rib belt…
06-24-2023, 08:48 AM | #9 |
Yea, the belt for my 3" pulley is a K080859HD. I assume my 2.75" is the same. I was looking at another belt.
'20 ZL1 1LE A10,
06-24-2023, 10:57 AM | #10 |
Thought so…
