Old 01-18-2020, 03:40 PM   #1
00Form
Drives: 2017 Camaro SS
Crank Pulley Bolt removal help needed
I tried removing with an electric impact and air impact and no luck. I even tried heating up the bolt. I also tried removing it with a breaker bar but the crank moves. The car is an A8.
I saw some posts where some opened up the bell housing inspection plate and wedged a screw driver in against the torque converter bolts and the side to hold the crank in place.
Can someone explain how they did this? I don't want to break anything.
Seems like some sort of flywheel holder tool could be built that fits into the inspection plate which would be real help.
Thanks
00Form is offline   Reply With Quote
Old 01-18-2020, 04:08 PM   #2
oldman
Drives: SS 6 speed of course
Heat and Lowe's 1/2 drive 24V impact.... works great.
There are inspection shields between the engine and trans, I have a M6 and there is one on the driver's side black plastic that is super easy to take off, 1 10mm bolt head. Get the impact cause the manual method is froth with errors.
You will need an autozone dodge damper remover (the list it as an installer) or that ain't coming off. three short fingers inside the damper.
oldman is offline   Reply With Quote
Old 01-18-2020, 04:13 PM   #3
parbreak
Drives: 2017 50th Camaro SS
Heated the hell out of it and zapped it a few times with 1/2" impact. Literally flew right off.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 01-18-2020, 04:22 PM   #4
parish8
Drives: 17 SS a8
yep, heat and a cheap 1/2" harbor freight impact and mine zipped right out. before the heat I couldn't budge it. I just used a burnsomatic for maybe 1 minute right on the head of the bolt.
dropped a valve in the 6.2. now running a drop in rods and piston 5.3
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472
parish8 is offline   Reply With Quote
Old 01-18-2020, 05:40 PM   #5
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG
I used this tool to hold the plate and used a breaker bar! sumbich was tight!!!
https://www.summitracing.com/parts/tfs-90326
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 01-19-2020, 06:40 AM   #6
00Form
Thanks everyone.
2018ZL1 - did you remove the starter to use this tool?
I bought a good Milwaukee 1/2" impact wrench 2-3 years ago and it didn't budge.
Thanks
Old 01-19-2020, 06:44 AM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
https://www.briantooleyracing.com/ls...el-holder.html
https://www.ebay.com/itm/LS-1-2-3-LS....c100752.m1982
the GM tool https://www.ebay.com/itm/Kent-Moore-...MAAOSwoydeC6qJ
Old 01-19-2020, 07:29 AM   #8
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
take about a 2foot screwdriver up through the round inspection hole wedge it against flexplate/converter bolt, put socket on crank pulley bolt and turn engine easy until screwdriver catches ,Heat is the Key!!! you gotta get that factory thread locker hot and the bolt will come out. Good luck! I used a breaker bar with a piece of pipe and it wouldn't budge , but once it got hot enough just the breaker bar did the trick , no need for special tool
DapperDan is offline   Reply With Quote
Old 01-19-2020, 08:09 AM   #9
2018ZL1
2018ZL1's Avatar
Originally Posted by 00Form View Post
Thanks everyone.
Thanks
Yep... that was pretty simple.
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
Old 01-19-2020, 08:10 AM   #10
2018ZL1
2018ZL1's Avatar
Damn! I wish I would have shopped around some! lol
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
Old 01-19-2020, 09:56 PM   #11
Clin5910
Drives: 2016 2ss, whipple supercharged
Remove black plastic inspection piece. Stop motor from turning over by wedging pry bar between teeth of fly wheel and trans casing. Heat crank bolt. And use the biggest breaker bar you can find lol
Clin5910 is offline   Reply With Quote
Old 01-20-2020, 02:29 PM   #12
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
I heated up mine as well, but I took the starter off, and had a pry bar wedged on the fly wheel. Even with the car in low gear and parking brake on, I was able to break the rear tires loose on the cheater bar taking the bolt out. she's on there pretty good.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 01-21-2020, 08:50 AM   #13
00Form
Well tried the heat and impact gun again and no luck, have the milwaukie 2763. I saw that the flywheel holding tools listed looked like an ls one which I had so I loosed the starter and pushed it out of the way. I was able to attach. Worked perfectly. With a breaker bar and a cast iron pipe I was able to loosen it. Was worried something would break. Luckily the socket was able to fit firmly to the bolt.
Next problem was my pulley puller doesn't work so ordered another.
Does anyone know if an ls crankshaft bolt works? Seems like they have a different part number so I probably stop at a dealer to pick one up.
Thanks for all the help.
Old 01-21-2020, 09:24 AM   #14
L78toLT1
L78toLT1's Avatar
Drives: Hyper Blue 2016 2SS 6M
Get an ARP balancer bolt. The hex head is 12 point and is much deeper. I always worried that the fairly shallow head on the stock bolt would round off when torquing to what must be at least 500 lbs needed to achieve the 90 degrees or whatever you're supposed to go to after torquing - can't remember the details but i recall having to put every bit of my 200lbs on a 36 inch cheater bar to get that s.o.b. torqued. I was surprised that i got it done without rounding it off. The ARP fits so snugly that you could jump up and down on the breaker bar without worrying about the socket slipping off
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned
L78toLT1 is offline   Reply With Quote
