Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 07-07-2015, 10:24 PM   #1
ClarityCamaro
ClarityCamaro's Avatar
Drives: 2013 black zl1
Need to beat my dads hell cat
Soooo I need to get my zl1 to beat my dads hell cat. I have a stock zl1 and my dad always wants to 1 up me. However we made a bet in 2 months when we go to the track that he won't beat me. However im a noob to zl1's love the car though. Just need it around 720 horses and not 580 input and advice wanted camaro5 good day!
ClarityCamaro is offline   Reply With Quote
Old 07-07-2015, 10:29 PM   #2
fiiggy
fiiggy's Avatar
Drives: 2014 SIM RS
Get ready for a lot of different responses.
MORE BOOST!
fiiggy is offline   Reply With Quote
Old 07-07-2015, 10:31 PM   #3
ChocoTaco369
145lb Powerlifter
ChocoTaco369's Avatar
Drives: 2013 Camaro 2SS RS LS3
Learn how to drive it. Your dad will probably sandbag the hell out of his Hellcat. The #1 mod you can do is the driver mod. An expertly driven stock ZL1 will smoke a Hellcat with a 2.4 60'.
ChocoTaco369 is offline   Reply With Quote
Old 07-07-2015, 10:37 PM   #4
ClarityCamaro
My dads a very experienced driver though that's the crappy part. Yeah more boost and lifted stock heads... Ehhh I'll pass looking for a shop around the Texas area that maybe can help me.
Old 07-07-2015, 10:38 PM   #5
forklord
forklord's Avatar
Drives: 2010 2SS
this. you also have better/wider tires. slight advantage. headers, pulley down and custom tune.... itll be drivers race
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 07-07-2015, 10:40 PM   #6
ClarityCamaro
Well this is just his street car he has a race car with 1800 horsepower however I would really love to just beat him with his street car
Old 07-07-2015, 10:53 PM   #7
silverbullet415
silverbullet415's Avatar
Drives: 2018 Camaro ZL1 1LE
Drag radials
silverbullet415 is offline   Reply With Quote
Old 07-07-2015, 10:54 PM   #8
Juiced1
Drives: 2012 2SS CAMARO 45th
Start bolting on parts. I've seen these Hellcats dyno around 640rwhp. To get to that horsepower range will take some serious mods. Most go with heads/cam/headers/pulley/od crank pulley/injectors to get into those numbers. We have some nice set ups available to get you there.
Old 07-07-2015, 11:18 PM   #9
motorhead
What's to keep him from modding the hellcat. I just read an article of one running in the very low 10's was not a lot of upgrades. Hell if he put slicks on he'll probably drop .5 to 3/4 of a second.
Old 07-07-2015, 11:44 PM   #10
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
If he can drive, then you're going to have to spend a bunch of money to even get close.
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 07-08-2015, 12:11 AM   #11
ClarityCamaro
I know that. Just need help getting there
Old 07-08-2015, 12:13 AM   #12
lscamaro
lscamaro's Avatar
If you're willing to spend the money, then it will take a full overhaul. Heads, cam, tune, pulleys for more boost, etc
Old 07-08-2015, 12:36 AM   #13
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
dont forget solid subframes. these cars loose time on getting the power to the ground.
"Z28 = first time I bought a new car just to strip parts for my current ride. GM needs to re-think restricted parts. "
macwest is offline   Reply With Quote
Old 07-08-2015, 12:49 AM   #14
one~Bad~SS
one~Bad~SS's Avatar
Drives: 2011 2SS/RS CGM LS3
You're kidding right? They have compared these two cars and yes the Hellcat has 707 hp but it is not a cornering car(although the they have made headway) it is heavier and therefore does not need much to beat the hellcat. Good tires, good driving skills, and a few bolt one is all he will need.
one~Bad~SS is offline   Reply With Quote
