06-21-2023, 07:27 AM | #1 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
P0300 supercharged high way pull?
Hello everyone, been a minute since I've posted anything. but last night was on the highway with absolute no one on the road, did a small pull coming from off the ramp to the highway, stayed into it till about 5th gear and let up (I wont' say the speeds) in anyrate, I see the check engine light flash on and off for about 45 seconds until i got off the highway. when i pulled to the stop light the light went away (went home and checked it). Keeping in mind that the car only has about 9800 miles on it, and when i was in it, I can tell that the supercharger belt was slipping as when i looked over i noticed that my boost gauge peaked at 8.4psi which I've never seen it go that high. (has been dyno tuned) a step down smaller pully has been put on, and the belt has not been replaced upon that new pully. Never really had any issues especially a misfire code. what I'm thinking is that with it being full throttle and the belt slippage (you can fell it) maybe the air/fuel wasn't getting?
- what are your thoughts? i did drive it around for a bit and light never came back on. I normally don't beat on my vehicles and thought it was a ok idea just to stretch her legs a bit.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
06-21-2023, 11:42 AM | #2 |
Misfire is frequently plug or plug wire related. What are you running for those items? I’m assuming you’re on pump gas 91/93?
06-21-2023, 02:37 PM | #3 |
HYPER SS
yes 93 shell for fuel. wires are stock, plugs are ACdelco 1 step colder (the ones that the ZL1 use for boost) not the stock SS plugs.
Ordered: 1/15/2016
06-21-2023, 06:08 PM | #4 |
Was P0300 the only code? You often get say, P0304, which would tell you the cylinder that’s having the issue.
06-21-2023, 07:48 PM | #5 |
HYPER SS
good question. yes. that p0300 was infact the only code. no other code was present.
Ordered: 1/15/2016
06-22-2023, 06:57 AM | #6 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Replying in a hurry, so apologies if i missed a detail somewhere. You said you never saw that high of boost. Could you be out of fueling capacity? Lean miss? Random misfire, not just on a single cyl?
Whats your fueling mods?
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
06-22-2023, 09:13 AM | #7 | |
HYPER SS
but as i was saying, the tuner said that he could tune it a little higher but the fuel would start cutting out at 600whp or so. right now I'm right around the 570whp.
Ordered: 1/15/2016
06-22-2023, 09:23 AM | #8 |
belt slip isn't going to spike the boost. If the belt slips the pulley on the supercharger isn't going to spin as fast causing a loss of boost due to less rpm. You likely just need to tighten the spark plug gap up a little bit.
2016 NFG 1SS A8
06-22-2023, 10:19 AM | #9 | |
06-22-2023, 01:21 PM | #10 |
HYPER SS
all makes perfect sense. thanks guys...
- whats wierd is hopefully its a 1 and done. as I've never experienced this before. only difference is. this was WOT from 2nd through 5 up till "x" mph. VS maybe light to light.
Ordered: 1/15/2016
06-22-2023, 02:27 PM | #11 |
If you have hptuners, get some logs. Yer a cold day away from engine damage if you are out of fuel capacity. Cold air takes more fuel... stresses the fuel system more. Long pull can make it worse too.
06-29-2023, 12:07 PM | #12 | |
Even at 6 psi the car will need a JMS fuel system voltage booster so the low side pump can keep the high side pump fed with that much fuel demand. 570 RWHP is the absolute Limit of fuel supply from the LT1 High pressure pump and injectors. This leaves no room for extra fueling to supply Cat Overtemp Protection will request. As soon as you exceed 6 ms of injector opening it will drain the high side pump and the car will misfire. When the low side drops the high side drops hard also. CAUTION MANY TUNERS WILL COMMAND A VERY LEAN POWER ENRICHMENT NUMBER TO STRETCH THE FUEL SYSTEM THIS IS BAD BECAUSE IT RAISES COMBUSTION TEMPURATURES WHICH EXPANDS THE RINGS AND LEADS TO DETONATION AND PISTON FAILURE At absolute bare minimum you need a JMS fuel system voltage booster. But I strongly recommend an LT4 fuel system upgrade package https://jannettyracing.com/products/...2018-camaro-ss 1LE cars and 19 up cars do not require the low side pump so you can select to delete that from the package.
www.jannettyracing.com
