Old 05-14-2013, 07:42 PM   #15
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
mickey Thompson et street ii drag radials
Rhino79 is offline   Reply With Quote
Old 05-14-2013, 07:51 PM   #16
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Awesome thanks!
Nightmare2012 is offline   Reply With Quote
Old 05-14-2013, 08:30 PM   #17
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
^^+1
Camarojt is offline   Reply With Quote
Old 05-15-2013, 12:06 AM   #18
62nalide
62nalide's Avatar
Drives: 2013 SS
Yes I will be running a drag tire so the 3.91 it is! Aggressive is what I want
62nalide is offline   Reply With Quote
Old 05-15-2013, 12:11 AM   #19
62nalide
62nalide's Avatar
Drives: 2013 SS
Originally Posted by smokum View Post
I have the adm gear swap. I installed 3:45 gears and it will lite up the 305's. I would maybe go 3:70 at the most. But once you get the hp up you will have a hard time finding traction. 3:91's are too aggressive. Unless your in the hunt for some serious burnouts.
How do you like those 3.45s? i spoke to ADM about the 3.91s I think thats more of the gear I'm looking for
Old 05-15-2013, 12:46 AM   #20
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
What if u just have headers ,tune and intake is 3.91 still to aggressive
Johnthegreat is offline   Reply With Quote
Old 05-15-2013, 01:50 AM   #21
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you have plans for FI in the near future, i'd probably go with the 3.45 rear gear. That way you won't have to swap back when you add it. Still should be a nice upgrade to what you're running now. If you're going to track it a lot, i'd go higher. I know Grocerygetter is running 3.70 with a vortech and first gear is pretty much worthless. Second isn't a whole lot better.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 05-15-2013, 01:54 AM   #22
62nalide
62nalide's Avatar
Drives: 2013 SS
Would like to play the NA game for a while, after the Turbo build the 3.27s go back in
Old 05-15-2013, 01:57 AM   #23
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
BTW 3:91 Gear can be had via GM at acheaper cost..
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 05-15-2013, 02:11 AM   #24
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
^ Everyone offers the cheaper price bc they too get them from gm. I'd stay with the stock gear (and I did) Saves money. Get a 3400 stall and call it.
K32 Camaro is offline   Reply With Quote
Old 05-15-2013, 08:01 AM   #25
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
do it the 3:91's are an absolute blast. really makes this heavy pig roll.
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ
APPEARANCE
COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING
biggerisbetter is offline   Reply With Quote
Old 05-15-2013, 08:15 AM   #26
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Your setup will determine if 3:91s are needed.
In my car (bolt ons + 3200 stall), I have no need for 3:91s. My car is already a handful trying to get traction on the street with 305 series drag radials.
I wouldn't consider 3:91s unless your cammed and need the extra torque down low. Otherwise its just overkill and will cause traction issues and extra shifts down the track.
I know several L99 owneres that took out their aggressive gears (returned to stock) and now they run faster times at the track.
SGOS252382 is offline   Reply With Quote
Old 05-15-2013, 08:25 AM   #27
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I would agree that 3.91's are more for cammed auto cars. They would not be the most ideal gears for a bolt on only car with a single disk converter or FI due to traction issues and a shift into 5th which is no bueno. With the right converter, cam and tires they look to be a great gear as evidence from Rhino's set up shows it.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 05-15-2013, 11:03 AM   #28
axis
Search Ninja
axis's Avatar
This.
I know Ryan is hitting high 6k if not 7k, in 4th, as he crosses the line. If you don't raise your limiter that high, you'll be shifting into 5th just before the line.
Halltech CF 102 fed
