02-09-2016, 07:30 PM | #15 | |
Drives: 2021 scatpack challenger 6spd cinna Join Date: Oct 2015
Thanks, Kevin Last edited by grahak2; 02-09-2016 at 08:13 PM. |
02-09-2016, 07:34 PM | #16 | |
Hi, Thought about using a cd holder but how do you get it to fit over the oem visor when it is smaller height wise than the cd holder? Thanks, Kevin |
02-09-2016, 07:36 PM | #17 | |
Hi Ron, That looks nice is it easy to do for a 1st timer? Thanks, Kevin |
02-10-2016, 03:48 AM | #18 |
Since I don't have any skills in this department I contacted an auto upholstery place to do this for me. I will post pics if I get it done.
Thanks, Kevin |
02-10-2016, 07:24 AM | #19 | |
Drives: 2014 2SS/RS Join Date: Dec 2014
If this is your first time doing a project like this I would give it a try on a spare one first and if it did not turn out well you could just pitch it. Here are the steps I did: - Remove visor from car by removing tiny phillips screws from swivel mount plate. The original plastic visor has a sleeve pocket over the visor that registration papers can be stored in; I completely removed the sleeve using a razor blade to cut it off where it is plastic welded. (this will allow bond of the leather, later, directly on to the visor surface). - Then HEAVILY modified a set of leather visor covers from an ebay vendor. Best to contact them to see if they will sell them WITHOUT Velcro closure and also provide extra sized leather on the top edge for closing up the pocket the visor slips in through. I dry fitted the visor cover first and trimmed/refitted the leather cover to fit better around the mounting points and seams and mirror window. The set of leather covers I started with were about $35, a year ago - it took an hour to modify them. - After dry fitting to make sure everything lines up well, took rubbing alcohol and wiped down the plastic visors so glue would stick well. - Placed some cotton in the corners of the leather cover to pad and slipped the plastic visor in to the leather cover. Moved cotton and added more until padding looked well formed in the corners. Used a long thin kids paint brush to spread glue on to the leather AND the plastic visor, all surfaces. (tube of Barge Leather glue). Let air dry for a couple minutes, then pressed down on the leather so it bonded solidly to the plastic visor making sure no wrinkles or stretching occurred. Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
02-10-2016, 09:53 AM | #20 |
Hi Ron,
Thanks for explaining in detail how to do that. Sounds like a good way to do it and the end result pictures you posted looked very professional. I'll see what response I get on an estimate and then decide what to do. Glad I got 2 options now. Although I haven't ever done anything like this so not really sure I could pull it off. But I gotta try something or I'll be keeping the window up right now. Thanks for taking the time to do the write up. Kevin |
02-10-2016, 10:04 AM | #21 | |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
02-10-2016, 10:33 AM | #22 |
Thanks man,
That's a good idea. I do a long drive to work around that time also. My windows are tinted pretty good but only have the sun problem with them down. It has been in the 70's and 80's right now in AZ and I hate to use the air when I can get fresh air. Good idea though. I am gonna go into the upholstery shop this week they said they would make me custom ones. If it is reasonable I may do it. I am not big on performance mods but comfort mods and safety mods like the locking gas cap I am. Thanks for sharing your method. Glad it worked for you! Kevin |
02-10-2016, 10:41 AM | #23 |
02-10-2016, 10:46 AM | #24 |
Drives: pleather and Chiclets Join Date: Mar 2012
I was just having this issue in redondo beach California. Want windows down 85% of the time but the damn sun was/is just hammering my face. Thanks for all the ideas. The organizer that is bigger is a well thought fix!
02-10-2016, 06:31 PM | #25 |
Drives: 2010 camaro 1ss Join Date: Dec 2013
was having the same problem couple of years back so I decided to tint the front ones and slap on some Oakley's and good to go!!
02-10-2016, 07:38 PM | #26 |
Drives: 2015 Camaro 1LS M6 Join Date: Jan 2016
I wonder if the 6th gen visors are bigger? If they are, could they possibly work?
02-10-2016, 07:46 PM | #27 | |
BCS Auto
02-10-2016, 11:34 PM | #28 |
SoCal C5 Family Member
Drives: 1996 Z28 SS & 2014 ZL1 Join Date: Apr 2009
The 6th gen sun visors are much bigger!
Vance Chula -
1996 Camaro Z28 SS #1688 2014 Camaro ZL1 Coupe #1956 |
