TireRack
Old 03-03-2015, 09:03 PM   #1
williamp78
williamp78's Avatar
Drives: 2011 2ss blk/wht strp
Whipple=boost
Anyone run a 3.125 pulley on stock internals?
2011 2ss black/wht stripes
"CAM only"
https://www.instagram.com/w_j_p_boss/?hl=en
williamp78 is offline   Reply With Quote
Old 03-09-2015, 09:21 AM   #2
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
we have some guys running that up here, but Albuquerque is much higher altitude. we can get away with it. i would be very careful of running that at sea level. could be dangerous.
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 03-09-2015, 01:07 PM   #3
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
im running 16 psi off a procharger on stock internals for over a year.... no problems
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 03-10-2015, 09:01 AM   #4
halo8hkk
centi are much more forgiving on a motor than a twin screw. 16 psi on a roots or twin screw on a stock motor will not hold up very long.
2000 Z28 = SOLD
IMB Silver Stripes
VIN#44025
Old 03-10-2015, 06:08 PM   #5
Rdunn
Really, Really Fast
Rdunn's Avatar
Well I was running 13psi on my whipple for a year before that. No probs
Old 03-10-2015, 08:50 PM   #6
williamp78
williamp78's Avatar
Like the comments. I've read threw here a bunch and haven't seen many peoples stories about trashing the engine from too much boost. Is psi not the same as other psi no matter where it's made from? I figure good meth and a good tune with good fuel presure will be just fine. I'm going to try and squeeze 15 psi out of mine and I'll let yall know if it goes up in smoke. But please keep the comments rolling. I like this place
"CAM only"
Old 03-10-2015, 08:53 PM   #7
williamp78
williamp78's Avatar
So two years all that pressure and still going strong. Nice!
"CAM only"
Old 04-05-2015, 08:47 PM   #8
ex-SS-ve
ex-SS-ve's Avatar
I will find out soon how well the stock internals take to some whipple boost. mine is sitting at g-force awaiting its tune and other supporting mods.
ex-SS-ve is offline   Reply With Quote
Old 04-06-2015, 08:20 AM   #9
kissmyss03
kissmyss03's Avatar
Drives: 2011 Camaro SS 2SS/RS
I have a 3.2 pulley on a twin screw
2011 Camaro 2SS/RS M6
Kooks Headers, catless mids, corsa exhaust, rotofab intake, SLP TVS 2300, 3.2 pulley, blower cam, cts-v fuel pump, Vector tuned 622 RWHP 573 TQ
kissmyss03 is offline   Reply With Quote
Old 04-06-2015, 08:42 AM   #10
z3R0fo01
z3R0fo01's Avatar
Drives: 2014 1SS RS 1LE tvs2300
Its a roots, but pretty close. Even though you are only at 8 psi, you are making a lot of power.
Supposedly its the power that destroys an engine, not the psi. High hp (even more needed to run blower) and high intake temp.
OP, as long as you get good gas and a good tune, it will probably hold for a while, as you have probably read. I would data log and be careful if you take it on a long trip. Use some decent octane booster if you are using unfamiliar gas stations.
What hp are u estimating? Also, do you track the car?
SLP TVS 2300 Kooks 1 7/8" Rotofab intake NPP
JRE tuned
z3R0fo01 is offline   Reply With Quote
Old 04-08-2015, 08:06 AM   #11
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
i'm running a 4 inch pulley with my whipple, and its hitting 9lbs of boost. Started with a 3.875 and it was hitting 10.1lbs. I backed it off to the 4" just for a little more safety.
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 04-17-2015, 09:01 AM   #12
williamp78
williamp78's Avatar
not sure what HP i will get but i am going alky meth, nw 102 TB, twin pumps. Im at 681 now with 8psi and stock tb stock pump with bap. Goal is 13-15 psi and see what it does. I have since decided to go with overdrive crank pulley and 3.5 whipple pulley. I do track the car occasionally and it is not a daily driver.
"CAM only"
Old 04-18-2015, 11:16 AM   #13
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Im assuming that 681 is to the crank?
Are you running a cam?
Nighthawk89 is offline   Reply With Quote
Old 04-18-2015, 12:36 PM   #14
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
I know of a stock ls3 (cam and spring only)that has a f1-x procharger on 23psi. Made 9 pulls over 1k this week on the dyno. Made 1034whp. With the proper fuel and tuning the ls3 is a beast of a motor.
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
