12-14-2021, 07:27 AM | #1 |
Drives: 2022 2SS Convertible Join Date: May 2011
Protecting roof seals and rubber
Hey guys,
Just wondering what you're using to protect the rubber, plastic and seals around the top. I was thinking of adding some chemical guys VRP for the UV protectiuon, but thought I'd give a shout-out first for some other recommendations. Thanks! |
12-15-2021, 06:13 AM | #2 |
Drives: 2017 SS 1LE Join Date: Mar 2017
I use to use something called gummyflenge or something like that. It was from Germany, Will see if I still have it in the garage and get the right name
12-15-2021, 07:50 AM | #3 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
Have been using VRP myself since I got the car, works great and easy to apply
12-15-2021, 06:44 PM | #4 | |
Drives: 2018 ZL1 Convertible M6 Join Date: Nov 2019
Close enough. Same here, I use this to quiet down anything that touches rubber and squeaks occasionally on both my 2018 vert and 2000 SS (especially the t-top seals): https://www.amazon.com/dp/B004B8GTQG...ing=UTF8&psc=1 |
12-22-2021, 09:24 PM | #5 |
Thanks! Got some that gummy pflege.
12-23-2021, 06:13 AM | #6 |
Cool, sorry I forgot but that stuff is the best..
12-23-2021, 04:55 PM | #7 |
UK2019
Drives: Camaro 2017 2ss/eu spec convertible Join Date: Mar 2019
Silicone spray
I've tried a lot of different products including gummipfledge but have found silicone spray to be the best to keep the seals fresh and stop things icing up and sticking in the winter
plastic, rubber, seals, top |
