Vararam
Old 05-01-2018, 02:53 PM   #1
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Vibration under heavy load...lets brainstorm!
2011 Camaro SS with 700ish rwhp.
Last july replaced my axels to DSS 1000hp axels as a precaustion. No vibrations. I then added MT ET streets for rear tires. no vibrations.
fast track to september. After driving all summer with my ET streets the car developed a vibration in the rear under load only. I could be going 80mph coasting with no issues. I only get a vibration when the pedal is to the floor and the car is torquing.
Stock transmission other than clutch. Stock rear end and stock drive shalf.
Drive shalf bolts are all in place and tight. axels are tight, all bolts on wheels are tight.
New rims and tires, mounted and balanaced, vibration still present under heavy load only.
So when i have the pedal planted mainly in 3rd gear and up the vibration is very noticable in my seat to the rear. The second i let off, it goes away.
Thoughts?
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 05-02-2018, 08:28 AM   #2
xc_SS/RS
Drives: 2010 Camaro SS/RS
did you happen to check any of the rear bushings?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-04-2018, 08:39 AM   #3
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
no haven't checked those.
Im scared its the actual axles themselves....
Old 05-04-2018, 02:00 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
There's another thread about a similar sounding problem.https://www.camaro5.com/forums/showthread.php?t=525284
If you're sure about the drive shaft couplings and bolts, and the vibration is under heavy load only, look at the engine mounts, transmission mounts, and rear axel mounts.
Old 05-04-2018, 04:10 PM   #5
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Thanks!
I think the shop figured it out...ill know more tomorrow
Old 05-06-2018, 05:34 PM   #6
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Everything was checked underneath by a local speed shop. Everything was tight and in working order. so I'm only assuming its got to be the axles. They are the worst at 2-3k rpms when punching the throttle. At higher rpms its not really noticeable.
I guess ill just send it and hope for the best!
Old 06-05-2018, 03:01 PM   #7
LHRxDeadx
LHRxDeadx's Avatar
Drives: 2013 Camaro 2SS Inferno Orange
did you figure it out?
LHRxDeadx is offline   Reply With Quote
Old 06-05-2018, 03:30 PM   #8
farm rat
farm rat's Avatar
Drives: 2011 Vistory Red 1LS
Throw out bearing?
The Original Farm Rat
2011 1LS M6 Victory Red
Sold
1967 Coupe Green and White
1969 SS 396 Hugger Orange
1969 Z/28 All original White with deluxe interior
1970 RS Blue
1978 Coupe Fugly Green
1978 WS-6 Trans-Am Factory 4 speed
1985 IROC-Z Red
farm rat is offline   Reply With Quote
Old 06-06-2018, 01:02 AM   #9
LHRxDeadx
LHRxDeadx's Avatar
Originally Posted by farm rat View Post
Throw out bearing?
i replaced mine that wasnt it
Old 06-07-2018, 04:02 PM   #10
redcoats1976
could there be enough slop in the engine/trans/rearend mounts to cause the pinion angle to change when the gas is applied heavily?
Old 07-30-2018, 01:25 PM   #11
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
No still haven’t figured it out
Old 08-03-2018, 02:24 AM   #12
LHRxDeadx
LHRxDeadx's Avatar
i havent either. ive got 4 drag days on it and a handfull of track days. whish something would just brake!
question do you have upgraded axels
Old 08-03-2018, 07:33 AM   #13
Nb1081
Drives: 10 2ss/rs
Sounds like a u joint in drive shaft but i just got one of these cars a week ago but ive had bad u joints that had no slop till u took it apart and the dry rusty needle bearings go flying out hell you coulda chucked a weight off the driveshaft and thats a lil out of balance now
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 08-04-2018, 05:26 PM   #14
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Ive checked everything....but yesterday i brought my Mickey Thompson Drag radials into the shop and had them road forced balanced. They were way off after only 400 miles.
I took it out for a rip, and there is barely any vibration anymore.
Im wondering if its been the damn tires the whole time.
