BeckyD @ James Martin Chevy
Old 01-12-2018, 01:22 PM   #15
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
Looks great OP, can't wait to see them installed. I actually like the Goodyears more than the Michelin PSS that were on my Z06, but the R888R is a bada$$ tire for sure.
Is it the lighting or are your headlights and driving lights tinted? I like the look.
Mcmillion is offline   Reply With Quote
Old 01-12-2018, 04:53 PM   #16
neenja_jenkins
neenja_jenkins's Avatar
Drives: 2017 Camaro ZL1
Man, I am so in for pics.
Gimme, gimme, gimme.
neenja_jenkins is offline   Reply With Quote
Old 01-12-2018, 05:01 PM   #17
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Mine go to the powder coater next week, going with gloss black. Will most certainly be asking about taping or placing a small washer over the bolt holes, never thought of that.
Op do you feel the location you used for the jack stands is better than the pinch welds?
I'm figuring mine will be on jack stands for about a week.
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 01-12-2018, 07:00 PM   #18
PinHead
Drives: Duramax
Originally Posted by Glen e View Post
Powder coating should be less than $100 per..... Call around though. Those look outstanding, I assume this was black gloss? Or powder coating black, then followed by powder coating clear?
But be careful when you tighten.....
I wasn't going to rain on his parade.
Powder Coater probably's taking advantage of all the Recreational Marijuana around.
I'd take them back as the resulting chips and cracks will cause future issues.
PinHead is offline   Reply With Quote
Old 01-13-2018, 06:31 AM   #19
McBrayer
Drives: 2017 ZL1
Sorry that I could not get any replies or pictures posted yesterday. I will do the best I can to answer the questions.
The color isn 't plain black, it is a metallic black power that closely matches the trim on my car.
I used a company in Covington KY that has done other wheels for me in the past called "Killer Koatings" It was $400.00 including striping the OEM gray paint.
Rear tire size is 315/30R20, Front size was to be 305/30R20 but dealer or I can not locate them. Dealer supplier said they had them, but it turned out false. Front is back on the factory F1s. I think I am going to just stick with this combo now and see how it goes. I tend to be a little too heavy on the right peddle so more bite out back will help with lack of driver skill, lol.
I rarely "track" the car, It is mostly a street car. The Goodyears that I referred to as "junk" are good tires in the proper application. In a street application, I consider them junk because you can never keep enough temperature in them. When the F1s are hot, they are amazing, but under that optimal temp, they suck on the steet, IMHO.
As for the R888R on the street, My ZL1 is my toy car, I only drive it for pleasure and play. If they last a summer and offer more rear end traction at "street" temps, then I have gotten what I wanted. I considered a drag radial but I wanted a tire that worked in the twisty stuff as well.
The wheels were top coated with "durable clear powder coat" that is supposed to be harder than the base coat. I had this same coating combo on my 2013 Raptor. They did really well on not scratching. A super fine polishing compound would bring any mistakes right out. Thanks for the heads up.
As for powder in the lug wells. This is my 4th set of wheels that I have had them do. The coating where the lug nuts contacts has never been an issue. I do run the lug on and off several times. The friction tends to melt the coating out of the way. I am a stickler about lug nut torque and I have never had the coatings cause any loose of torque and I recheck regularly.
Sorry for the crappy in garage only pictures. It started raining and then snowing here right after i got the wheels and tires home.
McBrayer is offline   Reply With Quote
Old 01-13-2018, 11:23 AM   #20
Sooner Cole
Sooner Cole's Avatar
Drives: 2019 ZL1-1LE A10
Looks good!
19 ZL1-1LE A10
Sooner Cole is offline   Reply With Quote
Old 01-13-2018, 03:01 PM   #21
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Anyone know a good, inexpensive powder coater. I did a google search and the cheapest quote was $125 a corner. That included me removing and taking brake cylinders out.
kwav8r is offline   Reply With Quote
Old 01-13-2018, 04:04 PM   #22
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Yup, that looks bad ass! Love it.
Can'tHave2MuchHP is offline   Reply With Quote
Old 01-23-2018, 01:11 PM   #23
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
How are you liking the r888r's in the rear? Fit well? No rubbing? Hook good?
Instagram: MattZ_L1 Vengeance Racing Built
Hellobatman is offline   Reply With Quote
Old 01-23-2018, 02:46 PM   #24
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
where do you live
speedraider is offline   Reply With Quote
Old 01-23-2018, 03:12 PM   #25
kwav8r
Flyin NOE
Originally Posted by speedraider View Post
where do you live
Eastern PA, until this summer, not sure after that.
Old 01-23-2018, 04:20 PM   #26
ReevZL1
ReevZL1's Avatar
Drives: 2019 Chevy Camaro ZL1 A10
I'd like to Chrome my Stock Wheels. Your wheels look good Black as well.
ReevZL1 is offline   Reply With Quote
Old 01-23-2018, 04:35 PM   #27
MOSAIC BLACK 1LE
Drives: Mosaic Black ZL1 M6
Have you put the 305’s in the front?
MOSAIC BLACK 1LE is offline   Reply With Quote
Old 01-23-2018, 05:21 PM   #28
speedraider
ok, if you were on the west coast, Here in Vegas its $100 per wheel. l've had 3 set of wheels done and they are always perfect. And as someone else was stating, gloss black will scratch easy as in swirl marks, Satin hides all the swirl marks.
