03-30-2024, 05:35 PM | #1 |
Drives: 2010 Camaro 1SS (BLACK) Join Date: Jan 2010
Codes p0300 & p0357
Hey guys so just had my check engine light come on, checked it and pulled codes 0300 and 0357
0300-random misfire detected 0356- ignition coil g primary/ secondary circuit. Just seeing if I can get some input about getting these 2 codes popping up. Haven’t checked anything yet as it just happened but will check the plugs, wires, connections. Let me know if anyone has experience with this. Thanks
03-31-2024, 05:53 AM | #2 |
Drives: 2010 Camaro SS2 2012 C6 vette M6 Join Date: Jan 2022
You may need fresh coils. Maybe sparkplugs. You may have gotten some lower quality gas and need to run some fuel injector cleaner. Stick with tier one gas stations and see how long its been for hard parts.
03-31-2024, 06:48 AM | #3 |
Probably coil.
04-01-2024, 11:46 AM | #4 |
Yea haven’t used cheap gas. Always use shell 91 octane so shouldn’t be that. How do you know if the coils are bad or need replacing? I reset the light to see if it comes back for now.
04-01-2024, 04:28 PM | #5 |
I would just swap the coil, But to be sure you can swap two coils and run the engine and check for the code to move to the cylinder you put the suspect coil. The pink wire(D) is ignition voltage and the black wire(A) is ground on all coils, You can check these with a test light or power probe. GL
04-02-2024, 08:48 AM | #6 |
Thanks for the info!
04-14-2024, 06:34 PM | #7 |
Ok so the cel came back on. Note sure if this is a coincidence or not but the first time the light came on it was raining, drove it for 2 weeks and it was raining today again and it came back on. And this time I also had the service stabilitrak message appeared with the 3 lights but turned off within 10 secs.
Same 2 codes as before. P0300 & P0357 The car seems to drive fine and not rough. I’m assuming to just start off with swapping the coil and go from there? If I swap 2 coils to see if it follows Would I just reset the light and wait till the cel comes back to read the codes?
04-24-2024, 05:26 PM | #8 | |
04-24-2024, 10:32 PM | #9 |
Yea I just replaced it today so I’ll clear it and see how it goes 🙏
04-25-2024, 09:48 AM | #10 |
Drives: 2011 IOM 2SS RS Join Date: Jan 2012
P0357:
Possible Causes Setting Conditions ignition Coil 7 has failed IC Ignition circuit is open (check the ODD INJ fuse in the U/H fuse block) IC ground circuit is open or has high resistance IC circuit is open, shorted to ground or shorted to voltage IC connector is damaged (check pins for damage, and for moisture) Ignition Coil 7 has failed ECM has failed |
04-28-2024, 05:22 PM | #11 |
Alright so after changing the coil the light came back on with same code.
Switched the new coil with another and it did not follow. So of course my luck it’s not the coil. Thank you for the break down of the possible causes I’ll will look into that. Hopefully nothing to crazy but I guess we’ll see.
04-29-2024, 04:09 PM | #12 |
Few things to test, Disconnect the #7 coil connector, There's four wires going to the coil, A is Black, B is Brown, C is Red and D is Pink. KOEO you should have ignition voltage on D(Pink). A(BLK) and B(Brown) are ground circuits. If not you will have to check the wiring. All odd coils are fed by fuse 10 so the fuse should be good or the whole bank would be dead but you could lose V after coil #5 in the harness if there's no V to #7. GL
04-29-2024, 08:47 PM | #13 |
Well when it comes to electrical I am very inexperienced. Will a multimeter work for testing the connector or do I need to get a circuit tester?
I also would think if it’s the fuse then all odd coils would be dead? Either way I checked the fuse and the fuse itself is intact and fine but I noticed the fuse pins or prongs not sure what they are called but they looked burned? Is that an issue or normal?
04-30-2024, 07:47 AM | #14 |
