Roto-Fab
Old 09-02-2008, 08:39 PM   #1
NOODLESgoneWILD
IS IT 2009 YET???
NOODLESgoneWILD's Avatar
Drives: '05 Z51 Black Vette & '06 H2
Send a message via MSN to NOODLESgoneWILD
LS376/480 EFI LS3 Gen IV V-8
Anyone seen one of these in action, they clain it has 50 more HP than the stock LS3...Id love it if GM put these in the Camaro SS
LS376/480 EFI LS3 Gen IV V-8 MSRP
$8,928.57
Enlarge image [+] 19171224
NEW LS376/480
What's Hot?
Hot cam
Big EFI power
24-month GMPP warranty
LS3 + Hot Cam = Loads of Fun
The hot new small-block V-8 in the GM lineup is the hyper-aggressive LS3. It offers a high-revving 376-cid combination that represents generations of small-block V-8 development and engineering. Not only is the LS3 an amazing engine in its stock configuration, but with those high-flowing rectangular port cylinder heads, the LS3 is loaded with potential. To tap into this, the engineers at GM Performance Parts offer you the LS376/480 an LS3 with an upgraded camshaft that ups power by a whopping 50 horsepower!
The LS376/480 comes with the same great features as the LS3 crate engine. The bottom end includes a 6-bolt aluminum block, nodular crank, high performance rods, and 10.7:1 pistons. The heads are high-flowing rectangular-port L92 units that have been upgraded with high-revving, hollow-stem valves. The same EFI intake manifold feeds the hungry engine, while 1.7:1 roller rockers work with the upgraded camshaft.
The GM Performance Parts engineers picked the LS Hot Cam (P/N 88958733) to take the LS3 to the next level. This cam specs out with .525" intake and exhaust valve lift. Duration (@ .050") is 219? intake and 228? exhaust, which allows for a dramatic increase in power. The engine will idle and cruise just like an LS3, but the power increase is there whenever you need it.
https://store.gmperformanceparts.com/store/SelectProd.do?prodId=7714&redir=true&manufacturer= GM&category=Engines&name=LS376/480%20EFI%20LS3%20Gen%20IV%20V-8%20&model=<!--19171224-->
Don't love me just for my FBod
NOODLESgoneWILD is offline   Reply With Quote
Old 09-02-2008, 08:45 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
you can build an engine with a lot more power for way cheaper.
im going to have just over $6000 im my 415ci LS3 stroker with cnc ported L92/LS3 heads and it will be easy 550hp+, parts are going to the machine shop next week,
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
camaro1 is offline   Reply With Quote
Old 09-02-2008, 09:25 PM   #3
NOODLESgoneWILD
IS IT 2009 YET???
OH no doubt you can do alot to the LS3 and make lots of HP, but the more HP I can get from the factory (500+)...with a 10/100,000 mile warrenty...ID be a happy camper!
Old 09-02-2008, 09:48 PM   #4
smokn'
Drives: Banana boat
$8,928.57
NEW LS376/480
What's Hot?
Hot cam
Big EFI power
so wait, is the cam the only difference? i thought our ls3 was already 6-bolt w/ w/ hollow stems and 10.7 pistons and 1.7:1 rockers? if it's only the cam, i'll be swapping that bad boy out in no time, if it's anything else to get to 480...:(
aside from all that, the ls3 does have enormous potential, especially when compared to the ls2. not that the 2 didn't, but the 3 is so much stronger and just all around ready to rumble!
smokn' is offline   Reply With Quote
Old 09-02-2008, 10:23 PM   #5
NOODLESgoneWILD
IS IT 2009 YET???
Not sure, have to do some reasearch....Im not sure if i total agree with you about the LS2 Vs LS3 There both great, but Im not sure the limitation of either...Im wanting to do more with my '05 vette (ls2) but im still gather info on how to get the most bang for my buck.
From what Ive read on the Corvette forums, most lean to going to 4.10 gears then Long tube headers.....then Cam...more to come on the subject.
Old 09-03-2008, 08:24 AM   #6
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
I'm sure LT headers, cat-back, and cai with that hot cam will produce more power then the 480. because that 480 is with the stock manifolds that come on it. . .
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 09-03-2008, 08:29 AM   #7
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
FYI....its only 5year/100K warranty.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 09-03-2008, 09:31 AM   #8
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
It's a stock LS3 +hot cam. Smaller lift on the intake than stock but more duration on intake and exhaust.
Robert91RS is offline   Reply With Quote
Old 09-03-2008, 09:57 AM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That cam won't pass a sniffer though, I'm sure. It would be nice, but I think that cam would be the problem.
I wonder how much closer to 500 horse' one could get using the LS7 cam. Those heads are CNC-ported, but despite larger displacement, more exotic parts, what is there to obstruct flow other than the heads and intake? I'll have to check into that because if that cam will smog in a Z0', why not an LS3? Yeah, there's a lot left on the table, but GM won't put non-smoggable cars on dealer lots.
'20 ZL1 Black "Fury"
Old 09-03-2008, 10:47 AM   #10
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
FYI, gmpartsdirect.com has a price on that cam:
GM PART # 88958733
CATEGORY: Engine Camshaft
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $520.00
OUR PRICE: $378.56
and the specs of the LS376/480 are the same as any old LS3, except for the cam... so this should be a direct swap without the need of upgrading springs, etc.
and I dont have to pass a sniffer... as long as the car plugs in and passes the OBDII scan, I'm golden
got tequila?
SilverTurtle is offline   Reply With Quote
Old 09-03-2008, 02:20 PM   #11
smokn'
Drives: Banana boat
that's what i thought. wow, just a cam swap and maybe intake/exhaust 500 ponies is right there! slap a blower on (or 2 ) and you're easily looking @ way over 600! in fact, going off of 500 as a base and using the 1lb=7% hp gained, i'm getting 745 hp@ 7 lbs of boost! but that's just my math.
Old 09-03-2008, 02:24 PM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
GM PART # 88958733
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $520.00
OUR PRICE: $378.56
Lucky
Old 09-03-2008, 02:30 PM   #13
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
I don't have to pass any kind of inspection at all.
- Xanthos
Old 09-03-2008, 03:42 PM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
- Xanthos
And, to you, I say: :slice: :middlefinger:
I didn't mean to come off like the idea was bad or anything, FWIW. I was making a comment more on how the topic was opened with the wish that GM would offer that cam in the LS3 in the Camaro. Again, not shooting down ideas, because come on, I want power too. I just wanted to be clear
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 06:02 PM
Condensation in late 4th gen headlights? MAC 4th Generation Camaros 27 06-30-2008 01:53 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
If the El Camaro makes it to production.... Silverado General Automotive + Other Cars Discussion 8 02-21-2008 10:17 AM
