Vararam
Old 01-29-2015, 09:40 AM   #1
TitusSS
Drives: ECS Supercharged 2010 SS
ECS supercharger without the restrictor
I'm going to get my car retuned for the alky control meth and the addition of the ADM FPCM (just had ZL1 pump and Kenne Bell BAP) and I was thinking about taking out the restrictor plate. I should have enough fuel with pump and ID 850's if the boost is not too high without the plate. Currently I am at 10 PSI and the existing plate was "opened up" by Matt Sorian when he tuned it.
Oh, I know there are other variables so to make this simple I just have headers and a stock bottom end and cam.
Thanks for any help you can provide.
TitusSS is offline   Reply With Quote
Old 01-29-2015, 10:52 AM   #2
bct10985
I dont think the zl1 pump/adm fpcm/bap will be enough fuel. A few members on here that had the restrictor removed and a cam made around 800 rwhp. It will make around 15 psi with the restrictor removed. If anyone would know it would be matt sorian see what he says and let us know.
Old 01-29-2015, 11:08 AM   #3
NOTAV6
Drives: 2010 ECS Camaro SS
To give you an idea of what a non-restricted car can do, my car dynoed at 798 without the restrictor on 14.5lbs or so. Stock block, Novi 1500, blower cam, Meth, Full exhuast, Lingenfelter twin pump setup, DSS 9in conversion and a 6 speed. Brain isnt working yet (super busy morning) forgot what injectors I have on the car.
NOTAV6 is offline   Reply With Quote
Old 01-29-2015, 12:44 PM   #4
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Don't go over 13psi for longitivtiy. More could and has been done but it's not worth the risk
DarkCry956 is offline   Reply With Quote
Old 01-29-2015, 02:58 PM   #5
TitusSS
thanks for the great feedback
Looks like it's time to get out the dremmel tool and go at the restrictor! Last thing I want to do is kaboom the motor. I'll talk to Matt and my awesome mechanic J-Rod and see if they concur with 13psi. Seems like a good number to me
Old 01-29-2015, 03:59 PM   #6
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
Im planning to unrestrict mine once I go bigger fuel system. Im at 680 with just the adm fpcm and zl1 pump at the moment.
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 01-29-2015, 10:45 PM   #7
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
13-15psi without the plate.
BLACK10 is offline   Reply With Quote
Old 01-30-2015, 08:05 AM   #8
pancherj
Drives: 2010 Camaro SS
Mine was touching 16psi and 850RWHP without the restrictor. I have the ZL1 and BAP setup with ID850's. It was showing signs of running out of pump. I would never race it at that level without more pump.
pancherj is offline   Reply With Quote
Old 01-31-2015, 10:49 PM   #9
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
You're pushing it at 13 lbs. Without the restrictor I was at 15.3lbs., making 811. Supporting mods is the key to make the motor stay alive longer, so meth is a good thing. LT's will help not only by increasing power, but it will relieve back pressure. If you just want to increase a few pounds of boost, every .1" is equivalent to 1lb of boost. If you don't have it already, you should definitely think of LT's. Power will increase, and boost will drop.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
SuperchargedStealth is offline   Reply With Quote
