BeckyD @ James Martin Chevy
Old 09-05-2018, 02:44 AM   #1
dreamst8
WrkrBee
dreamst8's Avatar
Drives: 16 Hyper & 11 Victory
2016 LGX V6 Engine Valve Cover Oil Leaking
Just rolled into 80K miles, and the dang valve cover gaskets look like they have been leaking for well over 20K miles, it was light surface oil slick, and on the "underside" of the block, so it was hard to see with just the hood open doing an oil change or cleaning. There was some that finally got onto the exhaust and the smell gave it away, then upon closer inspection..holy crap!! Anyone else having this issue? I am searching for TSB's , but no matter what, my crap-ass dealer will give me grief, so warranty was out at 60K, too bad they will say..
Anyone replaced theirs or torn the engine down that far? How difficult? Looks like it will be pretty easy, mostly getting the intake and fuel connections dismantled..
2016 Hyper Blue w/ Pearl White Rally Stripes, Black Interior 2LT/RS V6 A8,
Lights, Memory & Convenience Options
Sunroof
2011 2 LT/RS Victory Red V6 M6
dreamst8 is offline   Reply With Quote
Old 09-09-2018, 12:20 PM   #2
dreamst8
WrkrBee
dreamst8's Avatar
bump for advice/replies...
Sunroof
Old 01-31-2020, 01:53 AM   #3
Frommunda
Drives: Camaro 6 - V6
Bump!
Frommunda is offline   Reply With Quote
Old 03-16-2024, 04:53 PM   #4
JACisRAW
Drives: 2016 Camaro LT V6 3.6l
Did you find a solution to this? Were you able to do it yourself? I’m dealing with the same issue and looking around for some guidance
JACisRAW is offline   Reply With Quote
Old 03-16-2024, 04:58 PM   #5
dreamst8
WrkrBee
dreamst8's Avatar
I traded it off.. Not only had the bad valve cover gaskets, computer was malfunctioning, one bad strut, shitty floor mats worn out, seat back frame broke, transmission slipping again after the fluid upgrade, dumped it after the computer started to fall..
Sunroof
