View our official forum sponsors list. |
Thread Tools |
10-20-2015, 02:47 PM | #1 |
Quick Time Performance Low Profile Oval Electric Exhaust Cutout @ RPI Designs
This oval-shaped, low profile, electronically controlled SINGLE exhaust cutout means full control of your exhaust sound from the comfort and convenience of your driver seat. Designed for any car or truck that has limited ground clearance and anywhere from 2.25 inch to 3 inch exhaust pipe, this cutout will give you more sound, more performance, and not take up too much room under your car. With the Quick Time Electric Cutout you can have the best of both worlds - quiet for the street and wide open for the drag strip, autocross, or racetrack. Go from stealth quiet to wide open power and experience gains even if you're already enjoying an aftermarket exhaust system. You control the volume and you control the power. Open your exhaust with the flip of a switch or using our optional electronic controller (sold separately). Run it closed, run it all the way open or any position in between. Even try adjusting your exhaust's back-pressure to find the optimal gas mileage if you are so inclined. FEATURES: •Fits 2 1/4 inch to 3 inch Round Exhaust Pipes •CNC 6061 Aircraft Aluminum Body and Motor Plate •Stainless Steel Butterfly Plate and Shaft •Gears made from High Temp Steel for Long Life •High Torque DC Gear-Driven Motor (produces 1.5 ft-lb of torque) •Low Profile Design •Custom Illuminated Toggle Switch or Optional Controller •Weather Proof Wiring Harness and Connector with gold plated contacts •Made In the USA This SINGLE kit includes: •1 Electric Cutout Units •1 Gaskets •1 Wire Harness •1 Dual Momentary Toggle Switch •1 Oval Connection Pipes •1 Cover Plates •4 Bolts/Nuts/Washers Please note: There are a couple option available for this item please make the correct selection when ordering. This is a universal part and can be installed in a couple different locations. You need to chose the correct location that this item will work best for you. Website link : http://www.rpidesigns.com/shop/item....xhaust-cutout/ Last edited by RPIDon; 02-14-2017 at 11:18 AM. |
10-21-2015, 05:44 PM | #2 |
Can I ask what might be a stupid question to you but would you get any Benefit from something like this on a supercharged v6? I know and understand why they help on a v8 but I don't know enough about the v6 I figured you guys would know.... Right now I have a 2011 with headers and a Flowmaster axel back with the IPF supercharger and just trying to get more outta it
Sent from my iPhone using Tapatalk |
10-27-2015, 06:27 PM | #3 | |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
10-29-2015, 04:42 PM | #4 |
Yes that I understand it's the v6 part that I'm new to so I wasn't sure if there was any reason that it wouldn't work
11-16-2015, 07:53 AM | #5 |
03-17-2016, 01:53 PM | #6 |
A great way to wake up the neighborhood!!
07-01-2017, 09:20 PM | #7 |
2011 2SS m6 LS3
Drives: 2011 camaro 2ss Ls3 Join Date: Jun 2017
could I just get the motors my car already has cutouts from the previous owner. He left the box in the car but no controller for it so I guess I need one of those as well. Thanks
07-03-2017, 10:29 AM | #8 | |
12-15-2019, 06:20 AM | #9 |
Thank you for the orders!
07-07-2020, 07:29 AM | #10 |
Website link : http://www.rpidesigns.com/shop/item....xhaust-cutout/ |
11-09-2020, 08:58 AM | #11 |
12-17-2020, 09:04 AM | #12 |
02-11-2021, 04:55 PM | #13 | |
Getcha some of these!! They are great fun! This vid was done with my QTP's open, if you watch them you will see them open up at the 28sec mark..
08-05-2021, 09:38 AM | #14 |
Drives: 2010 2SS L99 Join Date: Apr 2010
Decided to go with these, mine will be delivered today and installed sometime next week once we make the appointment, I use Tune Time Performance in Lakewood NJ. Amazing shop with some of the best fabricators in the business led By the Guru himself, Matt... Will post sound clips then.. Car is already a beast with full ARH, High flow cats, Borla S-type axle back...
To Be Continued
