TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V8 Bolt-Ons & Tunes
Old 10-30-2019, 06:48 AM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
2010-2015 Camaro 5th Gen Pedal Commander Throttle Response Controller
In Stock Here!
Forum Members Save $39.95 w/coupon code PEDAL
Are you looking for instant throttle response while smashing the throttle on your 5th Gen Camaro? If so, then you want to pick up a Pedal Commander and enjoy all the benefits!
Eliminates Delay. Nowadays, vehicles are notorious for their delayed throttle response. That's where the Pedal Commander comes in. These days, vehicles use a drive-by-wire system that monitors the position of the gas pedal to control the throttle electronically, similar to a dimmer switch. The problem with this setup is that the signal from the pedal has to first be sent the ECU, which in turn then sends the signal to the actuator motor that controls the throttle body itself. This delay is most noticeable when trying to speed up to merge with fast moving traffic or pass a slower moving car. However, the Pedal Commander Bluetooth Throttle Response Controller will eliminate that delayed throttled response, giving your vehicle a drastic night and day difference in performance.
Four Adjustable Control Modes. Unlike other throttle control devices that are either on or off, the Pedal Commander comes with 4 control modes: Eco, City, Sport and Sport +. Best of all, each mode has an additional 8 different levels of sensitivity which allows you to personally adjust each mode to your own personal driving style and needs. Switching between modes can be done manually on the Commander or can also be done using your smartphone (Pedal Commander App), without having to bend over and physically touch the Pedal Commander.
Compatible with Aftermarket Programmers. The Pedal Commander can be used in conjunction with common aftermarket OBD-II programmers and/or monitors such as: SCT, Diablosport, Hypertech, Superchips, Bully Dog, and Edge.
2-Year Product Warranty. Pedal Commander manufactures their Bluetooth Throttle Response Controller to the highest quality and standards with CE and TUV Certification. However in the event you do receive a defective or malfunctioning device, Pedal Commander will replace it free of charge within 2 years of the original purchase date.
Easy Plug & Play Installation. The Pedal Commander Throttle Response Controller connects directly into the stock throttle position sensor found on the drive-by-wire gas pedal using an OEM style plug and play connector with no permanent modifications required. The Pedal Commander is 100% reversible making it warranty friendly.
APPLICATION: 2010, 2011, 2012, 2013, 2014, 2015 Camaro
southerncarparts is offline   Reply With Quote
Old 12-11-2019, 07:52 AM   #2
southerncarparts
Thank you for the orders!
Old 03-23-2022, 03:44 PM   #3
southerncarparts
2010-2015 CAMARO 5TH GEN PEDAL COMMANDER THROTTLE RESPONSE CONTROLLER
