Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V6 LGX Engine, Exhaust, and Bolt-Ons
BeckyD @ James Martin Chevy
Old 11-07-2023, 09:59 AM   #1
CYN_CRVR
CYN_CRVR's Avatar
Drives: 2023 V6 RS 6MT
Changing manual transmission fluid and differential gear oil - Any gotchas? (V6)
Is this a straightforward job if I've done it on other cars?
Any hot exhaust pipes in the way that I'll need to let cool down?
I've previously used a fluid pump and hose, but going to try the Amsoil "Easy-Pack" bags this time. Will I be able to directly reach the fill plugs, or will I still need a hose?
Thanks,
2023 V6 6MT: Riverside Blue, RS, Recaro, Brembo, NPP exhaust, GMPP suspension [view my build journal]
mods: BC Forged RZ21 19x10, Conti ECS 265/40, front splitter, FE4 front sway + endlinks, FEA rear sway + toe links
prior cars: NB Miata, C5 Z06, NC Miata
CYN_CRVR is offline   Reply With Quote
Old 11-07-2023, 09:30 PM   #2
Gen6cyl
Gen6cyl's Avatar
Drives: Chevy Camaro 2021 ,rs, v6, manual
I changed my transmission and differential fluids a year ago at 37k miles. It was easy as changing the motor oil. I used a $5 hand pump from harbor freight and the recommended ac Delco fluid and oil. I filled until it ran out the fill hole. The 3160 calls for dexron 6. A lot of on line info is from mustangs with the 3160. Ravenol is a German made dexron 6. I may use it next time. The oil plugs are not very tight. I took care to not over tighten them. It did shift better after the change but it probably has degraded since oil change.
B6 dampers, x pipe, mbrp axel back
Gen6cyl is offline   Reply With Quote
Old 11-08-2023, 08:08 PM   #3
CYN_CRVR
CYN_CRVR's Avatar
Cool, thanks for the response
Old 11-16-2023, 08:32 PM   #4
Matt1LE
Matt1LE's Avatar
Drives: 2020 3LT Camaro 3.6L 1LE
I'd also add that you can get o-rings for the rear diff plugs.
https://www.amazon.com/Dorman-097-13.../dp/B001SG7SSC
Also, here's a pic location of the drain and fill plugs for the Tremec 3160 transmission. Not the same location as the V8 manual Temec 6060 transmission. It's the two plugs in the middle of the picture that have the orange GM's version of Loctit. Much easier than the 6060 trans. You don't need to remove the sensor.
https://www.camaro6.com/forums/showthread.php?t=561622
Matt1LE is offline   Reply With Quote
Old 11-16-2023, 08:49 PM   #5
CYN_CRVR
CYN_CRVR's Avatar
Nice
Old 12-16-2023, 07:51 PM   #6
CYN_CRVR
CYN_CRVR's Avatar
Following up on this; I changed my fluids today and it was indeed very straightforward and easy. Also, confirming that no hand pump or extension hose is required with the Amsoil "Easy-Packs". Both fill holes are reachable with the spouts, and you just squeeze the bags.
Next time I'll definitely pickup some of those replacement rubber gaskets for the diff plugs.
Old 12-17-2023, 05:48 PM   #7
Gen6cyl
Gen6cyl's Avatar
Knowing that you can fill with the easy packs I may try amsoil. Can you give a update on any difference in the shifting, thanks.
Old 12-18-2023, 11:04 AM   #8
CYN_CRVR
CYN_CRVR's Avatar
I do feel that shifting is smoother, but it's not a crazy big difference since my OEM fluid only had 3,850 miles on it. This was my first break-in fluid change, and I'll probably do the trans+diff every 3rd oil change from here on out.
Two tips on the easy-packs for our transmission fluid:
1) It's difficult (impossible?) to get the last little bit out of each pouch. So, if the trans fluid isn't dripping out of the fill hole after you've squeezed all 3 of them, you can consolidate what's left of them into one pouch, and go for a 4th squeeze.
2) The trans case is quite thick at the fill hole, so don't cut the ATF bag spouts too short, or some fluid will dribble out as you're filling.
