07-07-2016, 09:22 AM | #1 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
How many miles does everybody have on their LGX?
We have a carbon deposit thread. A guy found a large carbon buildup on the valves of his LGX with only 4,000 miles on the clock. This could possibly be an isolated incident rather than something we can all count on happening to our engines. That's why I am wondering how many miles these engines have built up in this forum. And whether or not they have had problems along the way.
Life after retirement |
07-07-2016, 11:20 AM | #2 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
8200, and there's oil from the larger tube on the right entering the intake.
Not really worried though. My second camaro with a direct injection enginw. They make a cleaner for it, so really no need to worry or panic. It's not an epidemic or anything. Do any bit of research on GDI engines and you'll see this is a byproduct of direct injection. Heck, even boosted engines... good, efficient, but if the engine isn't built for, boost can shorten it's life. Nature of the beast
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant Last edited by PolynesianPowerhouse; 07-07-2016 at 11:31 AM. |
07-07-2016, 11:50 AM | #3 |
Drives: Gen 6 Camaro RS Join Date: Dec 2015
3,500 miles
07-07-2016, 01:04 PM | #4 |
Drives: 2016 V6 1LT RS NPP NFG Join Date: Apr 2016
574 miles.
07-07-2016, 03:11 PM | #5 |
@mart_add
Drives: 2016 1LT Camaro Join Date: Jun 2016
2,900
07-07-2016, 03:36 PM | #6 |
Drives: Hyper Blue 2016 1LT V6 Join Date: Jun 2016
I now have a touch over 800 miles and I'm loving it. I look for errands to run at home.
07-07-2016, 04:33 PM | #7 |
Drives: 2016 Chevy Camaro Join Date: Feb 2016
So far I'm in second with 7,000 Miles!
I don't have issues, but I have not inspected for carbon either. Whiskey |
07-10-2016, 08:34 PM | #8 |
Drives: 2016 Chevy Camaro RS V6 LT Join Date: Mar 2016
7,600 miles here
07-10-2016, 10:29 PM | #9 |
Long weekend of wrestling...just bumped that to 8870+
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
07-10-2016, 11:33 PM | #10 |
Drives: 2016 V6 Summit White/Adrenaline Red Join Date: May 2016
3600 here
07-11-2016, 09:03 AM | #11 |
Kywildcats
Drives: 2020 2SS shock and steel (shocker) Join Date: Jul 2016
Just hit 500.
07-11-2016, 01:50 PM | #12 |
Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
1150
07-11-2016, 02:18 PM | #13 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
just rolled over 3000 miles.
edit: this thread is related to the carbon buildup thread. I'm not convinced the amount of carbon buildup on 1 engine can be construed as the norm, but i'm not going to pull the engine apart to compare mine just for the fun of it. Couple things to note when / if you ever look in at the valves. What oil / how clean do you keep it (filter, change intervals), do you use and what fuel. I use full synth pennzoil (changed at 1500 and 1500 miles on the new oil) with fram ultra filter and 91 octane (most, if not all from shell). I think if there is a carbon buildup issue, it'll be heavily influenced by the quality of your oil and how dirty you let it get with some portion also having to do with impurities in the fuel. |
07-11-2016, 03:43 PM | #14 | |
Def true. Some oils aren't as stout as they claim. They break down under spirited driving via heat and the vaporization of various parts of the oil (base stock, additives, etc) are those things that adhere to the valves from blow by that is considered acceptable. Me I use 89 octane, some gas stations I go to aren't the greatest, but I use quantum blue custom blended oil. The first change was at 2844, and I'll run this till 10k on the engine which will be about 7k miles roughly and as on the last car, and the one before that, get an oil analysis to see if there's any wear I should be worries about on every oil change. I know a lot of people are freaking out about it, but it really is manageable. Nothing to panic about unless you just ABSOLUTELY SUCK at maintainence 😂
