TireRack
Old 06-06-2022, 09:59 PM   #1
427bbv8
Drives: 2008 z06
New to me ZL1 build
Just bought a 2013 Zl1 M6 black on black 19990 miles looking to dive into starting the build I want to max out stock pump on e85 with a BAP and max out the clutch all I do is roll racing. Was thinking of this
Headers or catless down pipes
Some kind of CAI that works with stock TB
Injectors BAP DSX flex fuel sensor
Catch can
Hoping this gets me over 600whp if not I’ll do a 10 or 18% lower reinforced brick ice tank and Heat exchanger
427bbv8 is offline   Reply With Quote
Old 06-07-2022, 05:16 AM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
congratulations on the zl1. i have a 90mm throttle body and 5" jlt intake i can give you a deal on. it will get you going in the right direction.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 06-07-2022, 09:41 AM   #3
427bbv8
Drives: 2008 z06
Sure! Pm me a price brother
Old 06-07-2022, 09:46 AM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Talk to Ted at https://jannettyracing.com/
Mods:
