Roto-Fab
Old 10-03-2016, 05:18 PM   #1
failshift
BMR LCA fitment or lack there of.......
Appearantly TCA028 is not compatible with fe6 like i was told by BMR........
(Assuming the fix is to get a fe4 bolt?)
failshift is offline   Reply With Quote
Old 10-03-2016, 08:14 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
BMR's website says that that arm is compatible with FE3 and FE4 suspension; doesn't mention FE6. Maybe an FE4 bolt is required?
KillboyPowerhead is offline   Reply With Quote
Old 10-04-2016, 08:24 AM   #3
failshift
Talked to BMR. Was told it's just an assembly snafu and the wrong metal collar was put in there. The correct one is being priority shipped. Great customer service
Old 10-04-2016, 11:58 AM   #4
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
headbang:
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 10-04-2016, 11:58 AM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, and I am sorry! The Sleeves were cut from the wrong material, then Cad Plated and put into the Arms/Bushings. I thought I had caught them all, but obviously some got sent out with the wrong ones.
Failshift, I packed your Sleeves myself and they are on the way!
T.C.
Old 10-04-2016, 12:02 PM   #6
failshift
T.C.
I appreciate it. Shit happens. I was just asking on here in case it was just a suspension based thing. Because I know the 1LE bolts have all been larger heads at the least than the ones the instructions for my subframe, trailing and toe rod have been.
Always happy with the top notch products though
Old 10-04-2016, 07:39 PM   #7
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Hmmm, the 1LE bolts should all be the same size as the SS bolts. What do you mean when you say the bolts were larger?
Old 10-04-2016, 07:53 PM   #8
failshift
The heads size. 18mm 22mm. Ect ect. Problem has been solved promptly
Old 10-05-2016, 10:58 PM   #9
failshift
T.C.
Just on all the fittings in general is there a need/amount of time that I should regrease/add grease to the fittings?
Old 10-06-2016, 09:47 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Depends on how you drive the car, how often and road conditions. On my car I try to do it every 3 months or so. Just remember to grease them up when you do oil changes!
T.C.
Old 10-06-2016, 09:52 AM   #11
failshift
T.C.
Low miles. But hard driving when it does get driven. Sounds like a good staple to follow
Old 10-12-2016, 12:17 PM   #12
failshift
T.C.
Buttoning it back up. Only suggestions would be maybe amend where it says "use a screwdriver to pick out the bushing housing" that was in no way/shape/form possible.
Cut a sliver out of it with an electric saw. Then punched it out with a chisel. But it took me an hour on the first one to figure that out. Second took 30min. Third was in and out in 10min
