01-11-2014, 09:46 AM | #29 |
Drives: Honda Accord Join Date: Oct 2013
I installed mine this morning. It's quite easy. Most time consuming part is lifting the car properly.
Once you have the car jacked WAY up, the OEM connector is on the SIDE of the transmission on the drivers side. The connector is not immediately visible because it has a thermal jacket around it to protect the wire from hitting the exhaust pipe. Just slide that cylindrical shape protector back and the plug will be exposed. Reach in with a small screwdriver to release the latch and pull the plug out. Install the eliminator between the trans and the original plug (it will only go one way-you can't make a mistake) and strap it back up. Be sure to position so that it does not touch the exhaust pipe. |
01-12-2014, 12:04 PM | #30 |
Drives: 2000 Camaro SS Join Date: Feb 2010
01-20-2014, 05:17 PM | #31 | |
Remove Before Flight
Drives: 2014 Cpe Z51 2LT Torch Red Join Date: Sep 2013
Z51, 2LT, 7-speed, Torch Red, Adrenaline Red, Red Calipers, Carbon Fiber Dash, Magnetic Selective, MyLink Nav, Black Wheels, Performance Exhaust, and Corvette Museum Delivery |
01-20-2014, 07:58 PM | #32 |
When I installed mine, I don't recall if there were 2 different connectors on the drivers side of the trans, however it is fairly high up on the trans and you do need to reach up there to get it. Skinny arms help. The connectors can only go in one way and the Apex connectors do match exactly to the factory ones. Remember that the connectors are not immediately visible-they have a small cylinder shaped thermal shield around them to protect it from the exhaust pipe.
01-20-2014, 08:54 PM | #33 |
Drives: 78 and 2014 Stingray Join Date: Nov 2013
Yes its the upper connection on the drivers side. The lower one looks like a temp sending unit.
01-21-2014, 12:37 PM | #34 |
Thanks, I'll try to upper one. It's a little harder to reach and disconnect.
01-27-2014, 11:01 AM | #35 |
05-15-2014, 10:44 AM | #36 |
Drives: C7 2LT Join Date: Dec 2013
Is the thermal shield re-used when the eliminator is installed?
05-15-2014, 09:05 PM | #37 |
Drives: 1974 & 2014 Corvette Stingrays Join Date: Mar 2013
Yes it is. I didn't even remove, just scrunched it up enough to connect the skip shift eliminator, then pushed back into place as best I could, given the tight space to work in.
05-16-2014, 07:18 AM | #38 |
Drives: 2014 Corvette 2021 Tahoe Z71 Join Date: Jul 2011
Please pardon my ignorance. So if I'm reading one of these posts correctly, if you are exceeding 20 MPH when shifting out of first, the "skip shift" is not activated, correct? I haven't been denied a shift into second yet, so I'm guessing I've exceed 20 MPH every time. Good assumption??
05-16-2014, 09:58 AM | #39 |
Good assumption, indeed. There are a number of conditions that must be met for the skip shift to activate (light throttle, certain speed, et al). These conditions seem to correlate to the EPA test cycle which is why Chevy does it. Makes for higher mpg and helps avoid the gas guzzler tax. When I was in stop and go traffic and wanted to shift to second gear, the skip shift was really annoying. I don't have that problem anymore!
05-16-2014, 07:24 PM | #40 | |
05-16-2014, 08:12 PM | #41 |
Part of the criteria the computer uses is % throttle. If you have the throttle open over the set thresh hold, it also will not engage skip shift. Skip shift only engages if speed is under 19mph, throttle is less than roughly 35% (I forget the exact %), and if load is minimal - all three. Just meeting one or two items still won't engage it. Unfortunately, those very criteria I encounter regularly to and from work, so in the eliminator went! Now I can control speed much better in stop & go traffic using the gas pedal, rather than getting on the brake constantly. Much better for brake longevity.
05-20-2014, 11:48 AM | #42 | |
Drives: 02Z06, C7 on order Join Date: May 2014
