Go Back   Chevrolet Corvette Stingray C7 Forum > Marketplace > Commercial Classifieds Marketplace > Exterior Parts & Accessories
Old 12-09-2014, 02:11 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
Check this out!! C7 Corvette APR Real Carbon Fiber Parts available @ RPI Designs !!!!
C7 Corvette Stingray APR Real Carbon Fiber Front Air Dam Splitter
If you are looking for the best quality carbon fiber to put on your new Stingray then look no further than this APR front air dam splitter. Made right here in the USA, this front air dam splitter utilizes a built in aerodynamic design that creates a high pressure region of air above the protruding surface, which helps reduce lift and increase high-speed cornering. Or course, if you are not into racing, this piece also provides a great visual upgrade over the factory look.
Get your order in today.
Item # FA-207007 $997.95 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4935
C7 Corvette Stingray APR Real Carbon Fiber Rear Deck Spoiler
This APR rear deck spoiler is made right here in the USA, is not only a beautiful piece, but is also designed to be functional, reduces rear-end lift and drag. This piece works great on its own, or coupled with our front air dam splitter.
Item # AS-105707 price $755.25 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4934
C7 Corvette Stingray Real Carbon Fiber Lower Diffuser
This C7 Corvette Stingray real Carbon Fiber Rear Diffuser is a direct replacement of your existing diffusor. Made in the USA by APR.
*Rear diffusers help reduce turbulence of the under-body airflow that exits the rear of the vehicle. This helps to reduce both lift and drag
Item # AB-277019 Price $1,465 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4971
C7 Corvette Stingray APR Real Carbon Fiber Side Rocker Extensions Skirts
If you are looking for the best quality carbon fiber to put on your new Stingray then look no further than this APR C7 Corvette Stingray side rocker extensions kit. Made right here in the USA, this side rocker kit helps reduce under-body turbulence, lift and drag by limiting excess airflow to the under- body. Or course, if you are not into racing, this kit also provides a great visual upgrade over the factory look.
Item # FS-207008 Price $1,610.00 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4936
C7 Corvette Real Carbon Fiber Front Fender Vents
This C7 Corvette carbon fiber side front fender vent set is a direct replacement of the OEM GM plastic pieces on the right and left front fender. Simply remove your existing vents and install this real carbon fiber vents.
Item # CF-700002 Price $456.00 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!!:thumbs:
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4932
C7 Corvette Real Carbon Fiber Hood Vent Insert
This C7 Corvette carbon fiber hood vent is a direct replacement of the OEM GM plastic piece. Simply remove your existing vent and install this real carbon fiber vent.
Item # CF-700005 Price $470.25 Use coupon code RPIDON5 on line or by phone and receive 5% off the listed price!!!:thumbs:
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4931
C7 Corvette Real Carbon Fiber Rear Quarter Panel Vents
This C7 Corvette carbon fiber rear quarter panel vent set is a direct replacement of the OEM GM plastic pieces on the right and left rear quarter panels. Simply remove your existing vents and install this real carbon fiber vents.
Item # CF-700004 Price $565.25 use coupon code RPIDON5 on line or by phone and receive 5% off the listed price !!!!
Website link : http://www.rpidesigns.com/shop/item.aspx?itemid=4933
RPIDon is offline   Reply With Quote
