Old 08-29-2015, 12:06 AM   #1
Dlsbobby
Dlsbobby's Avatar
Drives: 2010 Camaro ss M6
spinning to 7k
Greetings,
Say I wanted to spin to 7k with an aggressive cam lobe. I'm pretty sure I would need new rockers but could a hydro roller lifter make it or would I have to go solid roller?
TIA for your input.
Robert.
Dlsbobby is offline   Reply With Quote
Old 08-29-2015, 09:08 AM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
I have a VVT setup spinning to 7200rpms
Solid rollers are damn near 7500rpms
62nalide is offline   Reply With Quote
Old 08-29-2015, 09:18 AM   #3
Dlsbobby
Dlsbobby's Avatar
I'm a little confused, your VVT uses solid? Sorry I'm new to this stuff.
Old 08-29-2015, 09:22 AM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
No not yet, I'm going to do the switch to a VVT low lash solid roller
Old 08-29-2015, 09:33 AM   #5
Dlsbobby
Dlsbobby's Avatar
Ah got it thank you.
Old 08-29-2015, 10:02 AM   #6
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Hydraulic roller here with stock rockers and lifters (for now anyway)
No issues with +7,000 RPM
BFASTNOTLAST is offline   Reply With Quote
Old 08-29-2015, 11:14 AM   #7
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
If I remember correctly , reving past the point where higest torque and horsepower intersect is pointless. This rpm will vary depending on your mods. But I'm just an old man with a fuzzy memory .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 08-29-2015, 12:09 PM   #8
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
Our G6X3 cam package can spin to 7100-7200 but it really needs a better intake to do that well at that high of an RPM like the Holley high rise. Just wasting time really above 7000 on the stock intake
Anthony @ LG Motorsports is offline   Reply With Quote
Old 08-29-2015, 06:45 PM   #9
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
What about a FAST 102? That Holley isn't practical for the vast majority of users.
2018 Audi TT RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped).
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
2021 Charger Hellcat Redeye Widebody
Sold
USAFS197 is offline   Reply With Quote
Old 08-29-2015, 06:57 PM   #10
Unreal
Drives: 2006 Z06
Fast 102 still peaks out early.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 08-29-2015, 08:22 PM   #11
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
We have setups shifting in the 7200 range on hyd cams, ls3/7 lifters and stock rockers.
We have solid rollers going 7500. Both on our modified stock intake manifold.
Rhino79 is offline   Reply With Quote
Old 08-30-2015, 07:36 PM   #12
JayV83
JayV83's Avatar
Drives: 2010 camaro 2SS RS LS3
doesn't the torque and horsepower always intersect at 5252 rpm, being that hp is a calculated number from torque and rpm?
2010 Camaro SS LS3 Kraftwerks Supercharger 594rwhp 9.5 psi Dynatech 1.875" Headers, Dynatech Highflow Cats, 3" Flowmaster, JRE Tune, More to come!!!
1970 GTO Butler built 474 stroker, Pump GAS
1987 Monte SS Healthy sbc 5 speed
JayV83 is offline   Reply With Quote
Old 08-30-2015, 07:51 PM   #13
SSeniorMoment
Drives: 2010 2SS/RS LS3 A6 IOM
How much of a difference using your modded intake?
Also, what differences are you seeing at the strip between the VVT LLSR cam vs the 3-bolt LLSR cam w/3600 stall? Kip seemed hesitant about running the VVT LLSR cam and recommended going with the 3-bolt set-up.
SSeniorMoment is offline   Reply With Quote
Old 08-30-2015, 09:29 PM   #14
Rhino79
Rhino79's Avatar
VVT is still an advantage in street strip setups.
Where it becomes no benefit is when you have converter flashing 5000 plus rpm
Also the VVT cores aren't really designed for 700 plus valve lift.
