02-17-2015, 02:40 PM | #15 |
That's my concern. From my understanding, they can custom grind a FI-friendly VVT2 cam, if it's not already FI-friendly.
Did you have a bad experience before?
02-17-2015, 03:31 PM | #16 | |
Drives: Black L99 2SS/RS Join Date: Mar 2014
I'm running with LT Headers, CAI and a Tune. I want a very mild VVT cam but concerned with engine wear and drive-ability, this is my main vehicle/DD. |
02-17-2015, 03:41 PM | #17 |
Drives: 2013 SS Join Date: May 2013
Street/track warrior
02-17-2015, 03:46 PM | #18 |
Drives: 2018 ZL1 A10 Join Date: Mar 2013
450hp here with GPI vvt2,headers,air intake and exhaust. Stall coming soon
02-17-2015, 03:51 PM | #19 |
Sir, how is driving with the stocker converter? What's it idle at?
02-17-2015, 03:53 PM | #20 | |
'It's an experiment'
FI (Supercharger), does not need that much cam in an Auto so I'm going with a little bit less lift and more LSA (around 119 to 120) instead of the 112 I have now. I'm getting a custom ground VVT FI friendly cam so that will solve the vacuum and idle quality (again, I'm an A6). Cam specs play a big role if you are really going to go FI (Supercharged)... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
02-17-2015, 03:58 PM | #21 | |
02-17-2015, 04:01 PM | #22 | |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I have the GPI VVT SS3 cam and daily drive my car. (and have Bo White ported heads).
Based on what I've read I make maybe 475 - 485 rwhp...
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
02-17-2015, 04:11 PM | #23 |
You'll have better idle qualities, but it all depends on the cam choice. NA vs FI are very different requirements. You can go with a lower spec'd cam with FI -- If you're manual, then there may be less impact -- there are FI friendly cams that are manual only too -- that give you some real growl....
I can only say research and decide how soon you'll do FI. If FI is a ways out, then maybe get an NA cam now and swap out later for and FI. I did a lot of research, but found out the NA VVT SS1 was just not going to be a long term winner for FI -- and that is a baby cam too. Ryan (GPI) and I experimented with the VVT SS1 cam and we both came to the conclusion that the SS1 is a NA cam. I'd really talk to Ryan and let him know your plans -- he knows VVT inside and out... -Don
747 RWHP 794 RWTQ
02-17-2015, 05:30 PM | #24 | |
Drives: 2011camaro SS Join Date: Nov 2012
My car is a street driven car that I also race a lot. |
02-17-2015, 05:58 PM | #25 |
502 RWHP N/A
I have the gpi ss4 cam with a yank 4000 single disk stall. I've had this cam in my car almost a year haven't had any problems. I've driven from my house to 1/4 mile track which takes an hr make 10 passes depending on the day drive back home
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
02-17-2015, 06:48 PM | #26 |
Drives: 45th convertible ss Join Date: Oct 2013
Check out Nickey in St. charles, Illinois. They do great work. Not too far from St. Louis about a six hour drive.
02-17-2015, 08:09 PM | #27 |
He does VVT?
02-17-2015, 08:12 PM | #28 | |
Then later on I can swap the cam out and slap the supercharger on there. Ps. - What can I expect to pay for an install? I believe the parts (cam, sprins, rods, lifters) will run me about $800-900.
