08-11-2015, 01:03 PM | #169 |
Damn. They should have seen the TSB on this. Stupid service.
08-11-2015, 02:09 PM | #170 |
Drives: 2010 Camaro 2SS Inferno Orange Join Date: Sep 2013
Agreed, I have even been to more than 3 or 5 dealerships also
08-11-2015, 02:49 PM | #171 |
My dealership said no because I had already put my blower on.
Unbelievable. |
08-12-2015, 12:41 PM | #172 |
Yea, that makes perfect sense... They forgot to put a part on your car from the factory so a blower is going to change that..... Makes perfect sense...
10-03-2015, 02:25 PM | #173 |
Drives: 2010 SSRS Join Date: Apr 2015
Wow I'm glad a read through the entire thread. The last page and I find someone found the same thing as I did.
I have a 2010 build 123xxx with 20,000 kilometres and I also have the damn clicking noise. I got the washers and opened the rear up thanks to PQ diy vid, and saw that I already had the washer! So initial thought was "wtf is wrong with this thing now lol". I debated just putting the new beefed up washer over the stock one, but wasn't sure if it would interfere with a sensor or something. So now thanks to suicides work, I know what I have to do to fix my problem. Thanks guys
As I lay rubber down the street I pray for traction k can keep, but if I spin and begin to slide please dear god, protect my ride[/I]
10' ls3 2SS/RS, gfx pkg, stainless headers, 3" stainless exhaust, rotofab cai, custom stage 3 cam, 4:11 gears, wall tuned |
10-03-2015, 07:07 PM | #174 |
Okay so, bad news.. Installed the washers and the noise is still there
So, now what can the issue be?
11-05-2015, 12:28 AM | #175 |
07-18-2017, 04:14 PM | #176 |
Drives: 2012 camaro 2LS Join Date: Nov 2016
For some reason these part numbers for nuts and washers are not coming up anymore. I've done some research to see if I can find them but I'm not sure. Can anyone confirm that these are the right nuts and washers for the 2012 ss ? thank you!!!
Axle Nut 11611687 Axle Washer 11611965 |
07-30-2017, 10:37 AM | #177 |
Not sure. Hell I still have a washer and bolt that I never put on the other side. haahah
08-15-2017, 05:15 PM | #178 |
Drives: Black aSS 2011 - L99 Join Date: Apr 2012
What size are they? I don't live near a dealer and NAPA can't do anything for me. No one seems to be able to cross reference a part # with the GM ones from the video.
Staying stock and loving it............
10-09-2017, 12:55 PM | #179 |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
Did you ever get this resolved 05SilverStreak?
10-30-2017, 09:39 AM | #180 |
'It's an experiment'
http://www.camaro5.com/forums/showpo...&postcount=606
http://www.camaro5.com/forums/showpo...&postcount=629 http://www.camaro5.com/forums/showpo...&postcount=630 -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-05-2017, 07:26 PM | #181 |
Drives: 2010 camaro ss Join Date: Jun 2010
Im getting some clicking noise from my right side. Is this still possible with aftermarket axles? I can shake the axle a little bit while it is installed. So I took the axle nut off and pushed the axle as further in as I could into the diff. I tried shaking the axle again and it felt firmly in place. I installed the nut back in it and I can shake the axle again. Seems like the axle is coming out from the differential a bit after I tighten up the axle nut. Think these washers will fix my problem or is it the whole axle?
11-05-2017, 07:45 PM | #182 | |
IkoIko
I heard a clicking sound and took my SS to a dealership that I trust. It turns out the bolts are a "one time use and one turn" bolt. So if you are re-installing those bolts, it is advised to purchase new bolts. |
Thread Tools | |
